It is currently Wed Aug 20, 2025 7:39 am
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed Jul 01, 2009 9:05 pm
Davo111 wrote:
Sh1t there are more BUSHES that in the white house in America.... :wink: :wink:
:P Depends on what or what type of "Bush" you are talking about there Davo :!: :wink: :lol:
PostPosted: Wed Jul 01, 2009 9:12 pm
meeni wrote:
i shook the brap out of it and it doesnt move.. but im weak as p!ss so that doesnt mean anything :lol:
its not loose wheel nuts, i make sure theyre tight after loosing a rear wheel the other day :oops:
its not a handling problem because it corners fine and doesnt lurch under braking etc
engine mounts seem to be ok, though they arent new so il probably need to replace them..
i had a lower engine steady on the race car and it was good, maybe i need one of them too :wink:
all the control arm, tie rod etch bushes are fine..
excuse my lack of knowledge but whats a cotton real bush?
Do you have Nolethane top engine steady bushes (hard plastic/rubber....generally red in colour).
Cotton reel bushes generally hold the shifter mechanism to the floor and you will also normally find them at the rear exhaust mount at the back of the rear subframe.
PostPosted: Wed Jul 01, 2009 9:17 pm
ah ok, they are the same ones that came with the shifter, so il need to replace them too :roll: lol.. i dont have the urethane bushes in the top steadies, might invest in some.. where can i get them before saturday without driving anywhere as im working tomorrow and am testing at winton on friday :lol:
Potato
PostPosted: Wed Jul 01, 2009 9:45 pm
repco generally have the bushes or can get them in the next day
PostPosted: Wed Jul 01, 2009 9:52 pm
sweet, ive just ordered some new engine mounts from minisport
hopefully this all cures it
cheers guys!!! :wink:
Potato
PostPosted: Wed Jul 01, 2009 10:04 pm
ginger ninja
ginger ninja
Davo111 wrote:
SWAE, that knocking sound on your car is the poor defenceless men trying to get out of your car, and get away from your clutches and torture in the back seat....... :oops: :oops: :oops: :shock: :roll: :wink:
:shock: :o so is not! It's Gadgets trying to get into the car :lol:
sgc - I will investigate on the weekend
sports850 wrote:
PostPosted: Wed Jul 01, 2009 10:18 pm
Supercharged
its quite likely the exhaust hitting something, i think an extremely worn diff can clunk also.
PostPosted: Wed Jul 01, 2009 10:28 pm
Just before it goes BANG!! :shock: :P
PostPosted: Wed Jul 01, 2009 10:32 pm
:lol: thats highly likely too how do i check that in the car?
Potato
PostPosted: Wed Jul 01, 2009 10:34 pm
Tomboss Breweros
Use rubber (real) bushes.
They are a borstard to fit compared to nolathane or urethane but the car feels nicer and they last longer, heaps longer.
And what the other folk said, sounds like exhaust Vs subframe clunky.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Wed Jul 01, 2009 10:36 pm
Meeni wrote - "thats highly likely too how do i check that in the car?"
Put the car on a hoist, and in gear.
Go under, grab both pot joints together and rotate them to and for.
Any clunking noises or lots of movement is cause for concern. Usually a worn diff pin and planet gears is the cause.
If the pin breaks, it can come out radially and lunch your gearcase. Not a good look. :lol:
PostPosted: Thu Jul 02, 2009 5:36 am
Years ago We had a Mini Van which I used for work. When I bought a bigger van we used this Mini Van for doing pick ups and deliveries and at the same time my wife used it to do get shopping. One day she complained to me that the Van was making a clunking noise every time she put her foot on the brake pedal. So.. I took it for a drive around the block to see if I can work out what the noise was. Sure enough, put my foot on the brake and CLUNK ! did the same a couple of times and I figured it is coming from under the driver's seat. I stopped on the side of the road and lifted the seat to find a "TIN OF PEAS" rolling around and every time you break it was rolling forward and hitting that Box chassis bit across the car under the seats. That was very east yo fix.
"Let us remove your "SHORTS"
PostPosted: Thu Jul 02, 2009 8:03 am
i dont have a hoist but i put the car in gear and pushed it back and foward. the car rolls foward a fraction then grips up, i thought that was normal though, it also makes a little gear engagment sort of noise.. youve got me worried now!
Potato
PostPosted: Thu Jul 02, 2009 8:21 am
Pie & Mushy peas anyone ??? :-)
PostPosted: Thu Jul 02, 2009 8:34 am
diff is officially gone... :cry: now i can go to the mini cruise on saturday and minishow is looking like a tough ask...
how fun :evil:
Potato
Users browsing this forum: Bing [Bot] and 148 guests
