It is currently Tue Aug 19, 2025 11:02 pm
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Jul 02, 2009 8:38 am
If you have trouble finding new planet gears, contact Karcraft. :wink:
PostPosted: Thu Jul 02, 2009 8:42 am
I`ll guess that it is the exhaust clunking under there :-)
I was going to say maybe the rubber unis are flogged but it sounds like you have a roddy with pottys so i`m sticking with the exhaust being the culprit,,, maybe an intermediate or rear exhaust mount is broken-torn ???
PostPosted: Thu Jul 02, 2009 8:44 am
i dont think so now, ive taken dr mini's advice on msn and jacked one side of the car up, ive got an eighth of a turn movement on the wheel before anything happens..
Potato
PostPosted: Thu Jul 02, 2009 8:47 am
That sucks dude..
Best of luck getting it ready for mini50.!
PostPosted: Thu Jul 02, 2009 10:29 am
Supercharged
hope you can still make it to mini50
PostPosted: Thu Jul 02, 2009 11:11 am
You might want to check the drive shaft uni's. When they get loose they will give a bump as you transition on and off throttle.
Lift one wheel off the ground at a time, after placing your axle stands under the car give the wheels a rock back and forth. Check for movement in the uni that might show some slack. Repeat for the other side.
PostPosted: Thu Jul 02, 2009 6:16 pm
absolutely no movement in the drive shaft unis, cv's or the like. i took a video to better explain what i mean here..
i can hear gears rotating as i do this. but that probably means nothing... i dont really have the time to pull the motor out so if this is too bad, il have to miss minishow :(
Potato
PostPosted: Thu Jul 02, 2009 9:54 pm
I think you`re being paranoid,,, that seems pretty normal to me,,, have you checked the exhaust mounts??? & have you checked out how close the exaust system sits in relation to the body or subframe??? as in how close it is??? Have you checked the engine mounts but putting a jack "Under" the engine & jacking it up , jacking the whole car off the ground & looking at the engine mounts while it`s suspended off the ground with the jack taking the whole weight under the engine???
Most minis have a fair bit of play in the axle & diff assys,,, some more than others,,, i`d be looking a bit harder else where before jumping to conclusions,,,
Diagnose by looking, checking, double checking, inspecting, etc at verything before "DOING" anything else.... make sure you actually "FIND" the "REAL" problem before attacking "ANYTHING"
sorry to sound like i`m all bossy about it,,,, i just hate hearing about people ripping engines & diffs out """IF""" that`s not the problem
PostPosted: Thu Jul 02, 2009 10:03 pm
thats why i posted the video, as i wasnt sure weather it was the problem or not.. i replaced the passenger side engine mount recently but only put a second hand one in there to pass the roadworthy the next day, ive ordered some new ones, the exhaust mounts seem to be ok and i wiggled it around very hard and it didnt move any more then it should, il replace all of the cheap consumables like rubbers and bushes and see what happens, il also check the subframe for any obvious marks etc, when i go on the club run on saturday i might get someone of knowledge to come in the car with me just to see and hear it, if its not already fixed.. i definately dont think your being bossy, im more then happy to hear expierienced input, you know alot more then i do :wink:
Potato
PostPosted: Thu Jul 02, 2009 10:05 pm
:P :P :roll: What the F@%k would you know Matt :!: :P :P :lol: :lol:
PostPosted: Thu Jul 02, 2009 10:08 pm
hee hee,,, i`m a retired brain surgeon,,, what do you expect ??? :-)
Have you had a look at the brake backing plates,,, they do tend to come loose, but will normally only clunk under braking,,, not usually from throttle decelleration
Just a thought & only because some people on the net don`t quite explaing their problems that accurratellyyyyyy
:-) a bit lyk mie spelllyng :-)
PostPosted: Thu Jul 02, 2009 10:11 pm
TheMiniMan wrote:
hee hee,,, i`m a retired brain sureon,,, hat do you expect ??? :-)
:lol: You been into "Grandpappy's brew" Matt :?: :P :lol: :lol:
PostPosted: Thu Jul 02, 2009 10:17 pm
i got rid of them so its not that, its not a braking thing its the instant your foot comes off the throttle and the carb closes (the way s.u carbies seem to be a bit on the rough side on shutoff) it makes a clonk noise which sounds, as everyone has been saying like something hitting the subframe etc. i just want to be sure thats all
Potato
PostPosted: Thu Jul 02, 2009 10:24 pm
good for you meeni,,, definately do make sure,,, but just don`t jump to conclusions just yet.... is there anyone that is """VERY MINI SAVY""" anywhere near you who can go for a drive in it to feel it out,,, like BAlls-is-dick or someone like that???
Edit---> sorry,,, that should read """VERY mini SAVVY""" :-(
PostPosted: Thu Jul 02, 2009 10:27 pm
:lol: dont worry i dont understand why people complain about the capitol letters in MINI... he is in the greater region, accually i didnt realise he was only 2 minutes from my old tafe.. would have been handy when i was building the hillclimber there, doh!
Potato
Users browsing this forum: Bing [Bot] and 76 guests
