It is currently Fri Jul 18, 2025 12:27 pm
PostPosted: Mon Jul 06, 2009 9:39 pm
Hello All, We have our brick on it side all cleaned up, needing advice whether to spray/hand paint or spray with body deadener?? Cheers Stu
PostPosted: Mon Jul 06, 2009 9:47 pm
if its bare metal put a coat of etch primer down, then seal your seams, put on some body deadener and spray whatever colour you like over that, should seal it up good
Potato
PostPosted: Mon Jul 06, 2009 9:56 pm
Tomboss Breweros
What Meeni said.
Concerntrate where there may be panel gaps like along the sills :wink:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Tue Jul 07, 2009 7:46 am
I have done what the others have said. Be mindful that some of the deadners can be painted over and some can't. PM me your details and I can come and have a look. I have the shultz gun that you can borrow and give some tips etc.
Regards
Dave K.
PostPosted: Tue Jul 07, 2009 9:26 am
The original deadener was very thick, is it possible to get a product that will lay on as thick as the this?
PostPosted: Tue Jul 07, 2009 10:36 am
hey dave where did you get your rotisserie from?
PostPosted: Tue Jul 07, 2009 12:17 pm
and it was hard as concrete when set. Stuff i used on my Moke was soft as putty for ages. Seems the quality of the material & application method are both important.
PostPosted: Tue Jul 07, 2009 3:59 pm
Made it Josh. About $250 from memory. A little modified since these pictures were taken - now has pin locks for different positions.
Back under the house since the car is almost complete - so if you need to borrow?
Dave K.
PostPosted: Tue Jul 07, 2009 5:13 pm
I use K&H water based C guard. Good all rounder, easy to apply, the gun washes out with water, and the more layers you apply, the thicker it gets.
mooo, I'm a pig!
