It is currently Fri Jul 18, 2025 9:15 pm
Post new topic Reply to topic  [ 113 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: Fri Mar 04, 2005 4:53 pm
motor has to come out then,and crank and rods out?
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Fri Mar 04, 2005 4:55 pm
i'd say so....
things'd get a bit scratchy if you didn't, i'm guessing
PostPosted: Fri Mar 04, 2005 6:04 pm
MC_Cush wrote:
pocket'd block = lower compression ratio = more boost ;)
(well, a bit)
it's only 1cc or so. No big deal.
I did one in the car, once... :shock: 8)
Just tape all the holes up on top of block, put some grease around top of bore when finished, turn motor over. Presto! crud sticks in grease, wipe it out. Repeat until clean. :D
PostPosted: Fri Mar 04, 2005 7:14 pm
Bring your Die-Grinder one weekend.. I'll supply a carton of the golden liquid...... :D
J
PostPosted: Fri Mar 04, 2005 8:11 pm
is that beacuse there is a bigger gap in between the middle two cylinders on 998 compared with 1275?
PostPosted: Fri Mar 04, 2005 9:18 pm
Sort of partly the reason- it's that 1275 bores are not only spaced differently, bores are much bigger. So, the exhaust valves on a 1275 head overhang the bores on a 850-998-1098.
Inlets clear- just!
`Pocketing the block' involves grinding or milling the deck away along the gasket line of a 998 gasket (exhaust valve side), approx 2.5mm deep.
Full instructions are in Des Hammill's book- `How to power tune the BMC/BL/Rover 998 A series engine'.
Around $40 from Pitstop Bookshop, at www.pitstop.net.au
PostPosted: Fri Mar 04, 2005 10:38 pm
Am I correct in saying that you just follow the lones of a 1275 gasket to pocket the block for a 940 head 8)
PostPosted: Sat Mar 05, 2005 6:18 am
No- you follow the lines of a 998 gasket. But you MUST fit a 1275 gasket with a 1275 head- the 998 one won't seal the chambers.
PostPosted: Sat Mar 05, 2005 8:59 pm
think ill go for a standard metro engine modify it myself and fit a mirage motosport turbo manifold with a t2 or t25 probally start that when i finish school and get a proper job and it will be the best clubman ever 8)
PostPosted: Sat Mar 05, 2005 9:07 pm
2nd arfter mine :wink:
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Sat Mar 05, 2005 9:45 pm
lol i dunno mines pretty good
PostPosted: Sat Mar 05, 2005 9:52 pm
hah... no such thing as a good clubman!!! (watch the abuse come!!!! :D )
Jokes
My cr will be round 7.9:1 so it will be a bit to high to run much past 10psi i think.... well at least without an intercooler it aint the best idea....
68matic: "i havent seen much head in my life "
PostPosted: Sat Mar 05, 2005 11:57 pm
if i didnt think so highly of you duke nuke,i would have fired up :lol:
when i get kezjims old manifold and turbo,its gunna be bolted strait onto my 1098,get all the stuff made for the rest of it,and keep it at low boost,and just boost very quietly to work and back (under 1Km from my house) and sort out some bugs untill i get around to the 1310 with same turbo,im going for all low down response :lol:
drag ya some time :D
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Sun Mar 06, 2005 10:30 pm
hah! we'll see what happens.... 8)
GR built engine, with GR head and a nice t25 on the side of it :shock:
But you never know, I might keep blowing boxes and diffs, so I'll have to push it across the line :D
PostPosted: Mon Mar 07, 2005 7:51 am
just a quick update on my budget build that hasnt started yet.
I picked up 2 1.75 inch SU carbies from a Datsun yesterday for $50!!
Users browsing this forum: No registered users and 21 guests
