It is currently Mon Jun 23, 2025 5:44 am
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat Jul 11, 2009 7:53 pm
Anybody got a seal kit handy...:mrgreen:
PostPosted: Sat Jul 11, 2009 8:00 pm
I just checked & they`re the same size bore top & bottom,,, (shows i can`t remember everything hey?) :-)
so i spose it won`t really matter which way the pipes go hey?
PostPosted: Sat Jul 11, 2009 9:04 pm
Very interesting!! Quite an interesting topic really.
A tandem system I saw today (albeit it was on a Rover), had the bottom fitting going to the rear lines.
THE PLOT THICKENS!
But if it doesn't matter, then it doesn't matter.
Fingers crossed it doesn't matter!
PostPosted: Sat Jul 11, 2009 9:13 pm
Top is rear and bottom is front, that way if the fluid level falls you will still have front brakes ( well supposed to anyway :lol: )
Cheers Pete
PostPosted: Sat Jul 11, 2009 9:29 pm
Cheers Pete
[ edit] Dunno what happened here, I think I changed my mind about posting... :oops:
Last edited by drmini in aust on Sat Jul 11, 2009 9:42 pm, edited 1 time in total.
PostPosted: Sat Jul 11, 2009 9:31 pm
THE PLOT THICKENS!
Shouldn't a Rover have a diagonal split system? :?
PostPosted: Sat Jul 11, 2009 9:41 pm
THE PLOT THICKENS!
Some Rovers did, but then they woke up... :lol:
PostPosted: Sat Jul 11, 2009 10:14 pm
Well,,, i`m not well versed on Rover diag split systems but i`m assuming that the Master would have to be same bore top & bottom too,,, so it probably still wouldn`t matter
PostPosted: Sat Jul 11, 2009 10:27 pm
Just to add to the mounting evidence...top one goes to the front on this 50,000k 1275LS (Obviously a "pre-engine fix up" photo...)
PostPosted: Sun Jul 12, 2009 11:08 am
nah,,,, it looks like the top is going to the rear (single outlet on the valve is rear) on that one Mick
& i`m really starting to believe that the top is "Meant" to be to the rear,,, Dad`s 1275LS is also top to the rear & it`s std factory never been stuffed with,,, BUT!!! as the cyl bore sizes are the same top & bottom,,, the only reason i can see why the top should be rear is for that fluide level thing that Deluxe-68 mentioned.
PostPosted: Sun Jul 12, 2009 1:13 pm
This has got me a little bit concerned.
But... I am going to do the top outlet to the rear brakes.
I hope I don't have to re-make my lines if this isn't right :lol:
A very interesting topic, none the less.
PostPosted: Sun Jul 12, 2009 10:18 pm
Check it out!!!!
Me = HAPPY!!!
PostPosted: Sun Jul 12, 2009 10:19 pm
Very nice, William. What are those Wilwood valves worth?? :P
PostPosted: Sun Jul 12, 2009 10:27 pm
Most shops sell for around the $130.00 mark.
I paid a bit over $100 for mine... its good to have contacts :D
PostPosted: Sun Jul 12, 2009 10:33 pm
Tomboss Breweros
Looks very nice, good to see you didn't use that teflon coated pipe. The plating is better to look at 8)
kimini wrote:
