It is currently Fri Aug 01, 2025 11:29 pm
PostPosted: Wed Jul 15, 2009 2:43 pm
I'm bout to invest in a set of ratchet/geared spanner set (7pce). I've roughly priced up a kincrome set at work, and will do the same in a sec for sidchrome. Both have a 5deg/72tooth design.
Any advice?
I like sidchrome stuff... so if prices are pretty comparable i'd be going sidchrome.
PostPosted: Wed Jul 15, 2009 2:58 pm
I use sidchrome at work, admittedly i didnt pay for them so price didnt worry me, but they go good.
PostPosted: Wed Jul 15, 2009 3:04 pm
I use Bluepoint, Kincrome, TTI and Powerbuilt ratchet spanners on a daily basis,out of the three I like the Kincrome ones the best, as they have the smallest size head, making them good for confined spaces. Also they have a nice positive 'feel' to them (although that might just be in my head!)
Have had a few problems with the Bluepoint ones, swapped about 3 under warranty. No problems with any of the others.
Sorry, haven't used the Sidchrome ones, so not sure on them.
Andrew
PostPosted: Wed Jul 15, 2009 3:07 pm
I have a set of the Kinchrome ratchet stubby spanners (combination style)
Had them about 4 years, no problems except #1 son lost one :x
Only drawback is the thickness around the ratchet end - get whichever brand is thinner!
PostPosted: Wed Jul 15, 2009 4:14 pm
Tomboss Breweros
I heard theres a place in brissy that sells good ones :wink:
Gearwrench ones are my pick.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Wed Jul 15, 2009 5:43 pm
I recently bought a Kincrome reversible spanner set that is both metric and AF and covers 17 sizes which you change by swapping socket heads. It cost $79 reduced from $142 at Gasweld in Hurtle Square. Well made, properlver switch to change direction and very innovative design.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Wed Jul 15, 2009 6:39 pm
I've got the same set - they're lovely to use, but I often bump the little direction toggle switch while using them... that's a bit annoying
is that like a cross between a socket and a spanner? IE the handle is a bit like a spanner, and you put a hollow socket into it
I've got a set like that, awesome to use, but it usually stays in the cupboard, somehow it didn't make it into my "regular use" tools
PostPosted: Wed Jul 15, 2009 7:13 pm
I have a set of Gearwrench ones. Well made, but- don't buy the straight ones (no offset) that you have to turn over to reverse. They just do not fit in most places when needed.
PostPosted: Wed Jul 15, 2009 7:20 pm
i have a powerbuilt set, loving them.
PostPosted: Wed Jul 15, 2009 9:00 pm
Sears Craftsman :) and you can get neat little hex headed sockets to match - which I find myself using more often than not.
Cheers, Ian
PostPosted: Wed Jul 15, 2009 9:24 pm
I have a Kincrome set and they are great. Wish I had them years ago. But they appear to have only recently been invented.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Jul 15, 2009 10:07 pm
I think they might have been around for quite some time. My boss has a few scattered about the workshop which look as old as me. That might be exaggerating but ill take a guess and say 10-15 years old.
PostPosted: Wed Jul 15, 2009 10:34 pm
i have 2 sets of kincrome ratchet spanners had them for about 5 years never had a problem with them but try not to use them on really tight nuts or bolt's as that can damage them.
cheers dan
Cheers Dan
PostPosted: Wed Jul 15, 2009 10:47 pm
+1 vote for kincrome 8)
They come in varying shapes and sizes. stubby ones with the flexible neck are handy.
PostPosted: Wed Jul 15, 2009 11:22 pm
i have a set of kincrome but they have the flexi head. So those spots where the normal bent spanner wont fit you just bend the head a bit more lock it into place and then ratchet away. To change direction you shift head over the other way.
I think these these are much better then the solid state non-flexi head ones allows access to many more places
Users browsing this forum: Bing [Bot] and 85 guests
