pommie wrote:
I do have some new rubber strip for the doors, bought it many years ago and its been sitting on the shelf - I hope its still good. Has to be better than the siliconed up stuff that was on there. Did you use the rivets supplied or pop rivets? Thinking I will pop rivet them on, the supplied rivets look a little cheesy to me.
Si
Simon, I used the rivets that were supplied, even though they seem a bit cheap. I liked the small brass (real rivets) that were on there, but couldn't find anything comparable. I've had no issues in 5 years.
I also re-assembled my doors right after having the car/ doors painted, and I generously applied painters tape in 2 or 3 layers to the door frame before putting in the wing windows. They do rub the doors, so this will save your paint.
Another thing you might want to consider before re-assembling is the condition of your inside door latch mechanism
For about a year, my door latch has been hanging up slightly when using the inside door handle. It got worse after MMEMW in Winona to the point I couldn't open the door from the inside. Last weekend, I took out the inside latch assembly and found it worn. There is a cam that a stepped pin rides up and 2 springs that push down on the pin which forces the handle back down to the start position. My cam had worn unevenly, so the roller was stuck sideways in the latch assembly. The assy is riveted, so I drilled them out, opened it up, filed the cam so it was even and replaced the petrified grease with new. I replaced the rivets with 6-32 flat head screws which fit perfectly into the rivet counter-bores and lock nuts.
Now the latch goes almost 1/4" into the door when I open it from inside and the operation is much smoother.
Good luck with it.
