It is currently Tue Aug 05, 2025 2:10 am
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Tue Aug 04, 2009 5:11 pm
il describe the noise a little better too, its like a supercharger noise.. its not ear splittingly loud though.. thought it was the fan at first cos its a 4 blader but it goes away as i said..
Potato
PostPosted: Tue Aug 04, 2009 5:37 pm
Just a thought, do you have a return spring on the clutch arm?
PostPosted: Tue Aug 04, 2009 5:56 pm
yep, havnt got a fantastic pedal though :? cant work out why..
Potato
PostPosted: Tue Aug 04, 2009 6:26 pm
how long is the rod that goes into the slave cylinder. If its too long, as was what was the problem in my case, it will not return the bearing enough and it will be sitting on the diaphram, this will cause the bearing to spin all the time and you will get noise.
without the spring on, when you pull the clutch arm, do you get any clearance from the adjuster bolt. how far have you adjusted the bolt out. A new clutch wont need this adjusted out all the way.
for me the length of the rod in the slave cylinder cause ALOT of my problems being too long.
PostPosted: Tue Aug 04, 2009 6:57 pm
hmm something to check for sure! will go out and see!
Potato
PostPosted: Tue Aug 04, 2009 11:02 pm
hmm all appears to be adjusted correctly.. it couldnt be just a clutch noise could it.. i know its not a standard clutch
Potato
