It is currently Wed Jul 23, 2025 11:26 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 67, 68, 69, 70, 71, 72, 73 ... 568  Next
PostPosted: Sun Aug 16, 2009 7:42 am
4myego wrote:
OK Jim.
Yes shiny new drive, now Kev can drive down easy.
Concretor said, "no need to brake now". :shock:
YOu dont have to brake going down my driveway either.... but it is preferable :lol: :lol: :lol:
PostPosted: Sun Aug 16, 2009 8:21 am
Aaron,
Should have a sign at top of your drive
"Please use a low gear"
"Boris" - '69 Cooper S Mk 2
PostPosted: Sun Aug 16, 2009 8:44 am
4myego wrote:
Aaron,
and a parachute.
PostPosted: Sun Aug 16, 2009 10:22 am
Milatsmadmini
1310/71 wrote:
4myego wrote:
Aaron,
and a parachute.
Be prepared for smiles :lol:
PostPosted: Sun Aug 16, 2009 3:04 pm
I handed over the keys and waved bye bye to mine today.
It's off to a new owner in Newcastle who seems pleased with his new acquisition.
KB
PostPosted: Sun Aug 16, 2009 3:33 pm
KB
So now you're a 100% certified Frog driver again? :lol:
PostPosted: Sun Aug 16, 2009 3:59 pm
The TIG
This afternoon I worked on my girlfriend's Mini, I replaced the left side engine mount under the radiator, fixed a rattle in the heater controls, replaced the tracks for the roll down window in the right hand door, put a better looking badge on the hood. I washed it and gave it a good vacuum too.
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Sun Aug 16, 2009 4:01 pm
added a moke sump guard for rock bash protection, and modified the clubman budge bar ends to bolt onto the sump guard, so instead of one or the other i have both.
Not that the nudge bar will protect from roo's :lol: i just like the look of it on the front of the car.
But geez moke sumpies give you WAY LESS clearance under the front end of the car.
PostPosted: Sun Aug 16, 2009 4:08 pm
Just beware now that it's on , they can get you stuck ... If you have a couple of deep ruts going across the road and you get over the first but not the second you can't go backwards over the first as the rear of the sumpguard digs in ....
PostPosted: Sun Aug 16, 2009 4:13 pm
i have to take it off to do a couple of welds on the nudge bar.
Also make doing an oil change a pain too, so im going to do that before i put it back on again.
I did have thoughts about what youve pointed out, and was thinking about rolling the rear up it upwards and locking it to the rear of the subframe.
might have to get some hilos and jack em up full tilt to compensate for the loss of clearance.
PostPosted: Sun Aug 16, 2009 6:14 pm
KB
define what you mean by Certified, but yes. A Triumph motorcycle is now the only non-french vehicle contaminating the driveway/garage! :lol:
PostPosted: Sun Aug 16, 2009 7:37 pm
Location: Burpengary,Brisbane Nth(the better side of Bribane)
I put some relays on the headlights, it's amazing how much differance two extra volts makes :D
https://t.me/pump_upp
PostPosted: Sun Aug 16, 2009 7:44 pm
took the head off and gave everything the once over.... all looking good. Might get the head checked over by the pro's whilst it is off??
PostPosted: Sun Aug 16, 2009 8:01 pm
KB
Go the Triumph :wink:
PostPosted: Sun Aug 16, 2009 8:25 pm
Flat out answering PMs about the rear sway bar for sale :lol:
