It is currently Mon Jul 21, 2025 5:30 pm
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Wed Jan 12, 2005 3:51 pm
When It is in the tank then it will lube the Fuel pump a bit too.
It also makes more room in the engine bay without a kit on.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Wed Jan 12, 2005 6:38 pm
Wombat wrote:
Hey Kev - is FlashLube the same stuff that was around when we were kids that was called "Upper Cylinder Lubricant"? Used to be available in the Oil Rack at the servo's in a container that was a steel cone with a thing like a glass hypo syringe mounted horizontal on the top with a long thin nozzle about 9 inches long. You drew up a "dose" in the glass barrel then squirted it in the tank before filling. Cost about 5 cents a squirt.
Disappeared off the driveways along with the glass refillable Oil bottles.
Wombat,
You are probably thinking of Firezone, or Redex. They were just upper cylinder lubes.
Flashlube is a lead replacement additive but has upper cylinder lubricating properties too.
Good for my bronze valve guides... :P
PostPosted: Tue Mar 08, 2005 12:20 pm
BP Ultimate and a squirt of Flashlube is DEFINTELY the way to go...I won't put anything else in! I bought up the idea of putting an unleaded head on my engine with my mechanic (engine rebuild soon!), he says its a waste of time hardening the valves and seats when you can just use the squirt.
78 Leyland Mini - Prince
PostPosted: Tue Mar 08, 2005 1:03 pm
Oirdinary ULP isn't as bad as it used to be, but if you're running anything with a decent compression ratio, stick with premium and a lube additive.
If its a bunky with low compression the valves are probably the last thing to worry about. I've run several cars on unleaded with no additive - whatever's cheapest :roll:
Not recommended for longevity, but I've never heard of an engine dying from this type of abuse.
PostPosted: Tue Mar 08, 2005 1:04 pm
If the exhaust valve seats in the head are worn like many (most?) Minis are now, fitting unleaded seats is a good way to reclaim the head.
Or, fit bigger ex valves... :P
PostPosted: Tue Mar 08, 2005 2:59 pm
When I bought my Moke from the fella in Brisbane he told me to use Premium fuel with about 50mls of 2 stroke oil added into the tank :?:
Owing to the fact I have only fueled up 4 times in the last 12 months and have never done any long mileage as of yet, all seems ok at the moment.
Motor is a 1310cc and the head has been modified to use unleaded.
PostPosted: Tue Mar 08, 2005 5:53 pm
1. what does twostroke oil do to fuel for a two stroke motor?
2. how would that help a four stroke motor?
Inconspicuously Conspicuous
PostPosted: Tue Mar 08, 2005 5:59 pm
1/ ummmm... errrrrr????? :roll:
2/ ummmm....errrrr????? :roll:
PostPosted: Tue Mar 08, 2005 6:13 pm
1. It settles out and condenses onto the cylinder walls and bearings etc when the charge is compressed in the crankcase.
2. It will provide upper cylinder lubrication, in a 4 stroke motor.
One advantage of modern 2 stroke oils is they are ashless- ie. they don't leave lots of carbon etc behind when they burn. This is partly because `oil' comprises a lot less than 50% of the total volume. A high proportion is diesel or similar fuel (to promote self mixing in petrol), the balance is a `package' of anti-wear additives.
Source: I know an industrial chemist at Lubrizol, who make these `mixtures' up for Shell, Valvoline, etc. 8)
PostPosted: Tue Mar 08, 2005 6:29 pm
Two stroke oil's a hell of a lot cheaper to buy than any other additive.
Has anyone else heard of this working long term (not you Smokie - 80 litres of fuel a year does not count as a long term test).
PostPosted: Tue Mar 08, 2005 6:34 pm
No I haven't, but there's a rumour circulating in US that ATF (auto trans fluid) performs a similar function to lead replacement additives. No I haven't tried it either. :wink:
Moi? I just add 0.1% Flashlube to my BP Ultimate/Mobil 8000, etc. 8)
Done this for over 40,000 miles and after stripping engines a few times since, I know it works.
PostPosted: Tue Mar 08, 2005 9:10 pm
[No I haven't, but there's a rumour circulating in US that ATF (auto trans fluid) performs a similar function to lead replacement additives. No I haven't tried it either. :wink:
My brother and father both use atf in there cars ( hz v8 ute and 85 telstar ) They both do over 25,000km a year and they have done about 40,000km each with no problems at all. They use 5ml per litre of fuel or there abouts.
Cheers Pete
PostPosted: Tue Mar 08, 2005 9:32 pm
My advice would be to stop watching Today Tonight... its a crock of sensationalistic bullshit.
I use BP Ultimate and am getting through a bottle of Lucas Lead Replacer. I'll switch to FlashLube when this bottle is done. I've got an unleaded head but I will run the lead-lube anyway.
dwightgunning.com
PostPosted: Tue Mar 08, 2005 9:34 pm
You are dead right there! They didn't know the difference between leaded Super and LRP.
BTW my local BP still sells LRP... so much for their story!
PostPosted: Tue Mar 08, 2005 10:02 pm
Where can you buy Flashlube? Ive looked in Supercrap, AutoOne, and other local auto places but havent seen it on a shelf yet.
Im in WA, but if its one of the bigger chains ie Repco, then we have them here... ;)
www.crazybitchracing.com
