It is currently Sat Jul 26, 2025 12:39 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 70, 71, 72, 73, 74, 75, 76 ... 568  Next
PostPosted: Sun Aug 23, 2009 2:29 pm
ginger ninja
ginger ninja
Took off the old bits of chrome flare/sill trim that were left and fitted new black rubber trim :)
sports850 wrote:
PostPosted: Sun Aug 23, 2009 3:23 pm
yesterday, installed rover 65amp alternator, fixed a leak where the exhaust meets the manifold, fixed a couple of rattles in the engine bay, got steve to weld a bracket back up on my bonnet.
today bought and installed a new radio antenna that sits on the top of the windscreen. Installed new wiper blades.
this week, install new roof cage. Install UHF radio, and antennae.
getting closer to leaving Uggboot Central, Adelaide.
PostPosted: Sun Aug 23, 2009 4:30 pm
Made her shiney 8)
PostPosted: Sun Aug 23, 2009 4:40 pm
Milatsmadmini
mini maxx wrote:
Made her shiney 8)
and the mini?
PostPosted: Sun Aug 23, 2009 4:48 pm
finished painting the engine/parts and bought twin 1 1/4 su carbys off of ebay , $430 for the carbys and manifold , i thought it was a pretty good price
PostPosted: Sun Aug 23, 2009 5:17 pm
mattsmadmini wrote:
mini maxx wrote:
Made her shiney 8)
and the mini?
You Know im talking bout the Mini :P
PostPosted: Sun Aug 23, 2009 5:26 pm
turned over the motor by hand with some oil in the bores...
PostPosted: Sun Aug 23, 2009 5:30 pm
Did not.........you sweet talked a random male to do it for you :P :lol:
PostPosted: Sun Aug 23, 2009 5:48 pm
This space for rent
Finally hooked up the vac advance on the 123 dizzy correctly. I've been running it connected to the crankcase vent port on one of the twins, but discovered in an odds-and-sods drawer a PCV fitting for the manifold. So, fitted a reducer to that and attached the vac line there.
Haven't driven it yet, so have bugger-all idea if it'll make any noticable difference. Theory says I should get more advance with a crack of throttle (i.e. high manifold vacuum), which should improve fuel economy a bit and give a little better throttle response. Time will tell :)
PostPosted: Sun Aug 23, 2009 7:47 pm
went for a long drive with three other minis from melbourne to hurstbridge and beyond and finished at eltham .
a great day was had by all. :D :D :D :D
PostPosted: Sun Aug 23, 2009 7:51 pm
cleanded up the cooper S Block. Pic's in the Forsale thread :wink:
PostPosted: Sun Aug 23, 2009 8:08 pm
This space for rent
I sooo want to buy it, but the $$ escape me :cry:
PostPosted: Sun Aug 23, 2009 8:10 pm
Gave it a wash and fuelled up ready for drive your mini day on Wednesday
PostPosted: Sun Aug 23, 2009 8:11 pm
I is a mookenik
put a new radiator in the van that i got off drmini... took about 3 hrs to do. then changed a brake hose which took another hour.
PostPosted: Sun Aug 23, 2009 8:22 pm
Put a gas strut onto the bonnet then bent the bonnet when testing it.
Back to drawing board methinks.
Users browsing this forum: Sreedon and 90 guests
