It is currently Mon Aug 18, 2025 9:27 pm
PostPosted: Mon Sep 07, 2009 7:17 pm
Hi,
I have a 1 1/2 SU and iwas just wondering if it was normal for the piston (i think thats the bit that im talking about) inside the carby to be low? I will take a picture and post it up soon.
thanks
blake
PostPosted: Mon Sep 07, 2009 7:46 pm
Give Ash some flowers Nick .
When the engine isn't running/just idling the piston will be at the bottom of it's travel (basically as low as it can go). There will be a small gap to let a little air through (otherwise it won't idle).
I'll assess what you've said again once you post a picture of what you mean.
PostPosted: Mon Sep 07, 2009 7:55 pm
ok that makes sense anyway heres the pic:
But from what you said that makes sense
anyway thanks
Blake[/img]
PostPosted: Mon Sep 07, 2009 8:02 pm
That's what it looks like to me. The piston will raise up out of the way of the inlet runner once the engine is either revved but mainly once it is revving under load.
PostPosted: Mon Sep 07, 2009 8:12 pm
Ok cool thanks for that.
Blake
PostPosted: Mon Sep 07, 2009 8:34 pm
make sure you can lift the piston with your finger before using it and make sure its not too sloppy. the big black book tells you the way to test your piston. if its jammed or difficult to move you may have a bent needle or the piston/ bore is burred.
http://www.roversd1.nl/sd1web/carburation.html
PostPosted: Mon Sep 07, 2009 8:39 pm
This space for rent
With the dashpot piston removed (unscrew the black cap on the top of the bell housing and remove it and the rod inside) you should be able to lift the piston to the top of its stroke with absolutely no binding whatsoever, and when you drop it it should fall smoothly with a 'clink' as it hits the bridge. If it doesn't do this, you will get flat spots under acceleration.
PostPosted: Mon Sep 07, 2009 9:03 pm
I just had a look and yeh it moves freely but not sloopy.
Thanks for the replies
Blake
PostPosted: Mon Sep 07, 2009 10:18 pm
MINImal effort wrote:
that makes me go all tingly
PostPosted: Tue Sep 08, 2009 3:30 pm
This has nothing to do with SU's but how easy s it to install a Gemini Starter Motor? Is there lots of Mods needed?
Thanks Blake
PostPosted: Tue Sep 08, 2009 4:43 pm
Thanks Blake
You just need to move the bolt holes a bit and fiddle with the wiring. Only takes a short time to do.
PostPosted: Tue Sep 08, 2009 4:45 pm
ok sounds easy. is there any guide on how to do this?
PostPosted: Tue Sep 08, 2009 5:07 pm
the bolt holes just need to be elongated.
If you are planning to buy one, why not buy a new one from MG spares. The holes have been done for you, it comes with a wiring diagram and .....its new.
Only about $200 delivered from memory.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Tue Sep 08, 2009 8:29 pm
Also did the same and never looked back :wink:
Users browsing this forum: Bing [Bot] and 313 guests
