It is currently Wed Jul 23, 2025 3:00 am
 Post subject: brakes
PostPosted: Sat Sep 26, 2009 5:48 pm
hi i have replaced my front wheel cylinders , bled all , adjusted and i still dont have a pedal till the last little bit there is also a couple of drops of brake fluid below the brake pedal so am i right in thinking the problem could be with the master cylinder ?? is there anything else i should try before i replace the the master cylinder??
cheers jarrad
PostPosted: Sat Sep 26, 2009 6:03 pm
If its leaking inside the car then its a master cylinder issue and you will never get pressure until its repaired
Kiwiinwgtn
PostPosted: Sun Sep 27, 2009 6:37 pm
ok i will replace it and then see how i go .
PostPosted: Sun Sep 27, 2009 8:51 pm
http://www.ausmini.com/forums/viewtopic ... ht=#665620
Try first
Steve
"Boris" - '69 Cooper S Mk 2
