It is currently Fri Aug 15, 2025 5:20 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 83, 84, 85, 86, 87, 88, 89 ... 568  Next
PostPosted: Mon Sep 28, 2009 5:21 pm
Made her run today and took her for a drive. Very happy :D :D
PostPosted: Mon Sep 28, 2009 11:15 pm
This space for rent
Changed the top engine steady bar bushes on both sides, there was getting to be too much rock'n'roll up there on liftoff and acceleration and I was finding myself feathering the clutch at these times to prevent the engine moving around too much.
Now it's lots better, but it'll get even better still when I fit a gearbox steady bar in the next day or two 8)
PostPosted: Tue Sep 29, 2009 7:01 am
Online
Took the 175 main jets out of the 45 Dellorto and fitted 170s instead. It can now pull from 1500rpm (partial throttle opening), notwithstanding the 38mm chokes, RE282 cam and 1.5:1 rockers. 8)
PostPosted: Tue Sep 29, 2009 2:31 pm
Got my block, head and crank back from machinist :D
Now to start rebuild and to wait for cam and sc12 kit to be finished.
1965 Morris Mini Deluxe - 998cc SC12
PostPosted: Tue Sep 29, 2009 10:17 pm
This space for rent
Fitted a LHS lower gearbox steady bar and took it for a test spin. Improves the drivetrain shunt quite a lot, it feels a lot more like a remote box now 8)
There's still --> <-- this much improvement to be had, so I might fit the RHS one tomorrow ;)
PostPosted: Wed Sep 30, 2009 12:31 am
I washed the Asparagas Job bugs of the vans windscreen and took it for a fang around town. 8)
Image Image
PostPosted: Thu Oct 01, 2009 4:39 pm
This space for rent
Fitted the RHS lower gearbox steady last night.. drivetrain shunt is a thing of the past 8)
This one didn't go straight on however, it appears the lower primary case on UK motors are a little different to Oz ones, I needed a nut under the bracket on one stud to space it out a little.
I might take the evening off tonight and do nothing to it for a change :lol:
PostPosted: Thu Oct 01, 2009 4:41 pm
Yesterday bought some 5/32" x 1" screws - last night cut them down to 1/2" and fitted the petrol tank sender unit to the tank with them
David L
PostPosted: Thu Oct 01, 2009 4:54 pm
dropped the mini off at minisport for some work and called in at brickworx clearance sale and picked up a wiper motor and rear vision mirror , could of spent alot more there but the budget didnt allow it :cry:
PostPosted: Fri Oct 02, 2009 7:18 am
Tomboss Breweros
Re registered my blue one :mrgreen:
YAY
Might start polishing it with carnubara wax.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri Oct 02, 2009 7:19 am
Online
Got a pink slip for Mini HaHa, so he's street legal? for another year.:mrgreen:
PostPosted: Fri Oct 02, 2009 1:25 pm
Building one engine for the blue car, and refitting the front subframe and doing a head gasket to the red one.
Will the two cars be ready with two days prep between them? Find out tomorrow!
PostPosted: Fri Oct 02, 2009 1:54 pm
This space for rent
Had paint removed in three separate places, and chewed up a brand new windscreen rubber and locking strip.
Oh, and while that was going on, a windscreen was fitted.
PostPosted: Fri Oct 02, 2009 2:01 pm
Pulled out the dash on the Rover...
Pulled out a set of 8.4's from the old shell...
Put on an old drum set to be able to keep moving the old shell around...
Changed the plugs on the Rover...
Now trying to work out how to remove the top dash pad from the Rover without removing windscreen...?
PostPosted: Fri Oct 02, 2009 2:07 pm
Ordered some 0.6mm MIG wire and tips and a spot weld shield ( or rather a new general one as I'll butcher the old one to be a spot weld shield :wink: )
David L
Users browsing this forum: drmini in aust and 122 guests
