It is currently Sun Aug 17, 2025 12:39 pm
 Post subject: motor bike mufla
PostPosted: Thu Nov 23, 2006 8:43 pm
Hi guys
I was tossing :o up the idea of putting a 1000cc or 1200cc jap bike muffler on the mini. I would maybe bolt it cross ways between the rear subframe and the beaver panel. If I just ran a straight pipe with a 90 deg mandrel bend at the end, it would be simple enough and it would look pretty sweet, bit ricerish but wtf its my car. So the question I am asking is will it run or sound like crap?
Cheers in advance Michael
blokeinamoke wrote:
PostPosted: Thu Nov 23, 2006 8:45 pm
Your biggest problem might be that bikes have to meet different sound rules then cars , I think bikes can be louder than cars so you may have problems keeping the roar to a legal level . This is coming from someone who used to run a 1310 with a single 8" long hot dog for an exhaust though , man it used to sound good , especially at 3000rpm , it'd build up to a trumpet nlast at 3000 ....
 Post subject: mufla
PostPosted: Thu Nov 23, 2006 8:56 pm
thanks dude, I am in SA so I probly will get away with it.
blokeinamoke wrote:
PostPosted: Thu Nov 23, 2006 9:00 pm
PM supercharged850 , he was putting a couple of them onto one of his mini's , he'll know more about it .
PostPosted: Thu Nov 23, 2006 9:02 pm
I thought SA was the state with stringeant laws??
Are you looking for sound or performance?
 Post subject: performance
PostPosted: Thu Nov 23, 2006 9:08 pm
um....... performance firstly then sound secondly then cost thirdly then looks fourthl............ you get the point.
blokeinamoke wrote:
 Post subject: laws
PostPosted: Thu Nov 23, 2006 9:11 pm
the laws may be a little tighter, but we dont have roadworthys. If I can keep of the loud pedal around the cops and dont get defected and sent to regency(inspection place) I should be ok
blokeinamoke wrote:
PostPosted: Thu Nov 23, 2006 9:17 pm
998, 1098 or 1275? how hot/warm is the tuning?
Bike muffler and good straight throughs are no different as far as I can see. The one with the least restriction will work best. If you have to mount it at right angles, i can't see how that is better than say a centre exhaust straight through pipe and muffler.
Bigger is not necessarily better, remember that gas flows faster through smaller spaces. A huge exaust sytem will lose you torque if it is too big.
A standard issue 1 3/4" pipe and RC40 straight through system will work well for many applications, and as they are quite "standard" they may be cheaper than a custom bike setup ($140 for the muffler and $20 for the pipe from Karcraft for instance)
What type of exhaust manifold do you have? this would be the area of greatest restriction on std setups
PostPosted: Fri Nov 24, 2006 12:57 am
It has been done to minis all over the world..... and yes, you will probably want to fit a "hotdog" muffler aswell to help keep the noise down a bit. Doesnt really improve performance, just looks a bit different. Carbonfibre mufflers would look best.
Heres mine..... its from a BMW R1100S, stainless steel with chrome face plates... and cost a huge $65 (including postage) 8) ...................................ebay :wink:
Click on pictures to enlarge them
Image Image
Image Image
And yes, ground clearance is an issue..... the box is physically under the subframe cross bar.
PostPosted: Mon Oct 12, 2009 4:06 pm
What sort of sound levels are people getting with the bikes?
Under the old 100dba level ?
PostPosted: Mon Oct 12, 2009 4:51 pm
[quote="Lillee"]I thought SA was the state with stringeant laws??[\quote]
Yes and no.
The laws are different. They are tighter is some areas and looser in others. For example, your not allowed to (not supposed to) change the induction system (within reason of course) on a post 75 or whatever car due to emmission laws. But you can install an engine of any size and power to any car as long as an approved chartered professional engineer deems it to be safe and you give him a alarge sum of money! :P
In mini-dunger's case, if he doesn't attract the attention, he'll be right, :)
PostPosted: Mon Oct 12, 2009 5:49 pm
Another thing you have to consider is motorbike mufflers flow massive amounts of gas. Because a bike engine generally revs twice as high as a mini engine it has to flow somewhere around twice the gas. So I'm guessing a can from a 600cc bike would be ideal for most Minis.
PostPosted: Mon Oct 12, 2009 5:58 pm
Did anyone else notice the EPIC thread revival?
Simplify and add lightness
PostPosted: Mon Oct 12, 2009 9:51 pm
:oops: I've been thinking about it for a while.
Went into the local Suzuki shop today, but they reckoned they didn't have anything suitable, so I'm buying a slightly used system off a 650cc from the bloke standing next to me at the parts counter. Sorted! :D
Users browsing this forum: No registered users and 352 guests
