It is currently Thu Aug 14, 2025 7:29 am
PostPosted: Sun Oct 11, 2009 8:52 am
Replaced mates cv joint in his van splines to big in diameter had to linish down then the thread was wrong 18x1.5 instead of unf, lucky I have a lathe to turn and rethread nut or car would still be at my place why can't they supply nut if they change things
PostPosted: Sun Oct 11, 2009 8:55 am
I agree.
I had one recently on mini mad's car where the thread was metric, nut was supplied but 5mm too thick for the pin to go through.
I torqued it up, marked which slot, then milled that one 5mm deeper.
PostPosted: Sun Oct 11, 2009 1:11 pm
i bought one cv from minisport, and another from minitopia, both new, both looked the same.
but they both have a different thread and nut. one is 1 1/4, the other is 1 1/8.
PostPosted: Mon Oct 12, 2009 7:16 pm
You know what else annoys me, rear wheel bearing kits, the split pins are too big!
PostPosted: Mon Oct 12, 2009 9:13 pm
This space for rent
Ah, so it's not just my bad luck then :lol:
PostPosted: Mon Oct 12, 2009 9:27 pm
Yeap in the last year and a half i've had 4 different types of CV's with different thread/nut combos, nuts that are wrong, and the same deal with the splines too big as kev said...bloody stupid.
PostPosted: Mon Oct 12, 2009 9:49 pm
Your ears must have been burning!!! I was just bitching about that earlier :lol: :lol:
PostPosted: Tue Oct 13, 2009 12:01 am
"""Nothing""" is difficult,,, & the imposible just takes a little longer :-)
PostPosted: Tue Oct 13, 2009 6:25 pm
It just really annoys me when manufacturers make a product but they don't take a moment to think wether the split pin is right, or for example, a cv boot kit for some modern car i did a while back, it came with plastic cable ties, which weren't even big enough to go around the cv joint.... (not to mention they weren't metal ties, so i used welding wire). EPIC FAIL i say
Users browsing this forum: No registered users and 256 guests
