It is currently Mon Jul 28, 2025 10:29 am
PostPosted: Sat Oct 24, 2009 2:46 pm
I have a 9v battery but would it make a noise from that or does it really need to be 12v
PostPosted: Sat Oct 24, 2009 3:24 pm
Mods rock!
Try it. Shouldn't be too hard to rig some wires to try.
PostPosted: Sat Oct 24, 2009 3:33 pm
I think what deg is trying to figure out is if the horn works and wants to test it on a 9 volt battery ??? I'm not sure as I have a horn I could test here that I know works but no 9 volt battery ...
PostPosted: Sat Oct 24, 2009 4:29 pm
Thats exactly what i'm trying to do, damm it so close.
PostPosted: Sat Oct 24, 2009 4:33 pm
Just build a battery box with 8 x 1.5v AA. 9 v wont do it
PostPosted: Sat Oct 24, 2009 4:39 pm
it all depends on how excited the horn gets :lol: :lol: :lol: ..... but why onto batterys
PostPosted: Sat Oct 24, 2009 4:49 pm
Mods rock!
Appologies that my powers of ESP are not so good these days !! :lol: :lol:
PostPosted: Sat Oct 24, 2009 4:55 pm
It's cool , hang around here long enough and you'll start to regain your ESP :lol:
PostPosted: Sat Oct 24, 2009 5:02 pm
Yes but you can't help the vague questions.
No, horns require too much current, which 9 volt batteries cannot provide. Horns can use quite a bit of juice.
Use a car battery charger instead, it has 12 volts and a little extra mumbo, or do the right thing and get a multimeter, can't go wrong, they start at seven bucks these days.
PostPosted: Sat Oct 24, 2009 5:06 pm
could i cut the end of a 12v adapter? or do i risk getting electrocuted
PostPosted: Sat Oct 24, 2009 5:22 pm
only if you tape the 12v end across your exposed heart. The 240v end is a different story.
PostPosted: Sat Oct 24, 2009 5:32 pm
12 volt adapter what?
No you won't get electrocuted, unless you cut a 240 volt plug..but you do will ruin whatever that 12 volt adapter thing you have is. If you mean a 12 volt power supply for a phone or whatever it is, they often have a very low current capacity as well. Get the multimeter, avoid the bodgy shite.
PostPosted: Sat Oct 24, 2009 5:35 pm
take the horn to another car and just put the leads across the battery
PostPosted: Sat Oct 24, 2009 5:37 pm
Or just unplug someone else's horn and connect yours
PostPosted: Sat Oct 24, 2009 5:39 pm
Nahh , unplug the wires from their starter motor and hook them to your horn , scares the bejeeser's out of them , can be fun to watch them try and figure it out too .... Kept an Engineer at Goulburn scratching his head for an hour :lol: :lol: :lol: we didn't call him Goombah (for nothing :lol:
Users browsing this forum: Phil 850, Steam and 70 guests
