Thanks guys thats more like it I put up a post last week on a similar topic and it didn't fly . I am running a minisport water heated manifold the hs6 is from a 1500 with a TD needle , which I will have to change, I have changed the angle of the float bowl to the correct one , and I intend to run a K&N filter cone type with a sub stack ,which I will pick up in the U.S. when I go there in a couple of weeks , and I did take note of radiusing the carby inlet . Engine is 1293 , stock head @ rockers 10.3-1 comp, waggott997 cooper cam, modified dizzy, what is the suggestion as far as needles are concerned , OA6 seems a popolar choice . Oh and it has maniflow extractors if that makes any difference
_________________ That's why it's good to be.............ME
