It is currently Fri Aug 15, 2025 11:02 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 94, 95, 96, 97, 98, 99, 100 ... 568  Next
PostPosted: Mon Oct 26, 2009 9:36 pm
Cut a perforated section of metal out of the right rear quarter where the seams at the bottom. Began welding in a new piece.
PostPosted: Mon Oct 26, 2009 9:40 pm
Armoralled the buggary out of her :lol: and cleaned up all the door jambs
PostPosted: Thu Oct 29, 2009 3:41 pm
Tomboss Breweros
Pressure backflushed the radiator and engine seperately.
Put green stuff where there was red stuff :oops:
Put a new radiator cap in place of the broken one.
Put pop rivets in the back ends of the chrome trim strip cos they kept moving out.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Thu Oct 29, 2009 3:52 pm
finally bolted on her non functioning pollution pump ( just 4 looks), lost a nut and washer somewhere but found them again when i started her up and the rad fan spat em out into the rolla door :shock:
PostPosted: Thu Oct 29, 2009 5:58 pm
new fuel line hoses, fuel filter and swapped the rear brake pads and new rubber seals for the handbreak hole thingy. bought some ss split pins for the axel nuts.
PostPosted: Thu Oct 29, 2009 6:50 pm
Swapped my 180 air corrector jets for 170s. Will go for a drive tomorrow with a wideband A/F meter hooked up.
PostPosted: Thu Oct 29, 2009 7:37 pm
This space for rent
Finally got around to buying a set of new piston springs for the carbs, chucked a matched pair of reds in to replace what appears to have been one red, one blue :roll:
PostPosted: Thu Oct 29, 2009 11:49 pm
Engine went back in today :D
However I am still trying to get the last uni joint on :evil:
1965 Morris Mini Deluxe - 998cc SC12
PostPosted: Fri Oct 30, 2009 7:41 am
You may need to either lift the engine up slightly or remove the wheel and top ball joint so the drive shaft has a bit more movement.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Fri Oct 30, 2009 7:01 pm
Cheers, will give removing the ball joint a try. Tried moving the engine up and down to get some clearance but couldn't get enough room.
Do you need to grease the uni joints? I know oil kills them but wasn't sure if they go in dry or greased up.
Haynes manual says nothing.
PostPosted: Fri Oct 30, 2009 7:32 pm
Give Ash some flowers Nick .
Changed over to a new (recon) generator as the old one stopped charging.
PostPosted: Fri Oct 30, 2009 8:23 pm
pulled the gearbox apart and found a tooth missing on 3rd.... joy....
PostPosted: Fri Oct 30, 2009 8:54 pm
Took her for a drive to Supercrap and got mobbed by question askers.......Luv it :lol:
PostPosted: Fri Oct 30, 2009 9:20 pm
i put my new carpet in worked out i'm crap & trimming cut my custom carpet in the wrong spots!! gave up called my mate..
$50 & 1hour later it's all in nice haha.
did the brakes after i got the little crap of a rusted bleed nipple off.
bled them all up for the first time in my life.. was easy proud of my efforts!!!
the pedal stops like rock!!!!
i'm so close to getting her going again she is looking HOT!!!
photo's will be coming in a new thread..
put new rear wheel cylinders on...
Users browsing this forum: No registered users and 259 guests
