It is currently Sun Jul 27, 2025 2:20 pm
 Post subject: Cold starts
PostPosted: Sat Nov 07, 2009 11:39 pm
I have finished my rebuild and started her up today.
A problem I've had in the past and even now after the rebuild is that when I first start the engine, I find it impossible to open the throttle up. When I do the engine revs don't change at all, sometimes it stalls and when I put even more throttle the carby backfires.
When the engine is running at it's normal temp everything is fine.
Carby is a HIF44. Before the rebuild I had a mechanical fuel pump, now I am using a Fedtro pump.
Of course I am only applying a little bit of throttle but it still just doesn't seem right.
Is this a carby problem? Does it need a rebuild?
1965 Morris Mini Deluxe - 998cc SC12
PostPosted: Sun Nov 08, 2009 1:06 am
Sounds like it`s in perfect tune to me
but.... does it do that same thing if you try to rev it with the choke on (when it`s cold that is) ???
SU carbs (when in good tune) don`t like starting ,,, or running very well,,, when they`re cold,,, if they do then they`re set too rich
Soooo,,,, if it coughs & splutters when it`s cold "Without" the choke on,,,, but it`s all good when it`s warm..... then it sounds perfect to me
But that`s just me,,, others may know better,,, lets get their storys/thoughts/ideas/experience too & you can make an Informed judgment
PostPosted: Sun Nov 08, 2009 6:16 am
Mine is similar....When its cold it will splutter and cough back into carby. If I apply choke it runs okay and once nice and warm it runs really well.
At first I thought I had a problem so I changed plugs, checked timing, topped up dash pot oil etc and it did improve but still doesn't like running under load when its cold. I am still thinking of doing a carby reco to ensure everything is right with the SU but apart from that I think patience in the morning will fix my problem. :)
1971 Mini K
 Post subject: Running rough..
PostPosted: Sun Nov 08, 2009 6:46 am
It is very true what Matt is saying. Mini Engines with SUs don't like to run too well when cold unless the choke is used. Choke needs to be left on till engine starts to run a bit Rich and ruogh then slowly eased off. If engine runs well when it is warm it is a sign thet the Carb is fine. Don't touch it ! Be a bit more patient with it when cold and give it time to warm up. Running engines flat out before they warm up does not do them much good.
"Let us remove your "SHORTS"
PostPosted: Sun Nov 08, 2009 9:50 am
This space for rent
Matt's right :)
Mine doesn't backfire through the carbs, but you've little chance of starting it without the choke at all. Once it's running it'll fart around a bit being too rich, but if I back the choke off to just over the fast idle setting it runs fine.
If I try to go without choke too soon it complains bitterly, but once the temperature needle starts to move it's usually OK.
If it starts and runs well cold without choke, it's too rich.
PostPosted: Sun Nov 08, 2009 12:26 pm
Sounds normal then. It does idle fine, the reason for asking is since it's a new rebuild engine with a new cam, I was trying to not let the cam idle. Is there a way around this?
 Post subject: no choke?
PostPosted: Mon Nov 09, 2009 8:30 pm
Hmm interesting, after recently fixing my dizzy, my carbs no longer require choke in the morning. (But its a lot warmer of a morning atm)
So hypothetically if the carbies are now too rich, how long would I need to run the car for before the spark plugs will show signs of blackening aka proof its too rich?
Jonesy
Michael Jones
Minis In The Gong
[email protected]
www.minisinthegong.com.au
 Post subject: Re: no choke?
PostPosted: Mon Nov 09, 2009 9:47 pm
This space for rent
Depends what sort of driving you do, but usually not very long -- I find my plugs will change colour with half an hour or so of running after a tweak or change of fuel brand.
PostPosted: Mon Nov 09, 2009 9:56 pm
Tomboss Breweros
Mine won't fire up unless the throttle is left shut or near shut, then has a bit of a carry on and starts to cheer up.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Mon Nov 09, 2009 10:00 pm
Water heated manifold , Grill Muff , correct timing , tappet gaps reset - good idle under choke , 45 sec till revs rise , reduce to 1/3rd choke and drive off, as soon as the temperature gauge crosses the bottom line choke fully in.
Well that was the routine in the "Snail" ! :D
[img][img]http://img267.imageshack.us/img267/2766/p1000415.jpg[/img][/img]
