It is currently Mon Jul 21, 2025 8:33 pm
PostPosted: Wed Oct 28, 2009 7:23 pm
Phat Kat wrote:
74snail wrote:
Also PK are you looking at doing some for the rear door window's on Van's ?
Now that would be good !! 8) :)
Good question,,
If you just need them for your rear window(s), call your local auto glazier, most of them can fit a demister to your existing window.
The ones I'm looking at for the front are completely transparent, no lines... so for the rear this set up isn't 100% needed.
No, No just the rear door windows only, some of us have solid side Van's and it just sounds like a good idea, especially if you are in an area prone to frosts
PostPosted: Wed Oct 28, 2009 7:30 pm
74snail wrote:
Good question,,
How's this for frost prone areas!!!
Yeah sorry Dean, I meant the van door windows, I didn't write it very well.
Alex
PostPosted: Wed Oct 28, 2009 8:29 pm
MinisPlus
I'd be keen on one, like everyone else, it would depend on price :wink:
How can it be rusty when it's covered in so much oil?
PostPosted: Wed Nov 11, 2009 11:08 pm
Okkie dokkie,,
I heard back from these guys today.. heres the deal
Morris1100 to answer your questions.....
"Heat wire diameter: Ø0.03mm,
Wire to wire distance: 3.0mm
Heater Resistance: 0.51Ω
Voltage: 12v
Amp: 23.5A
Wires separated to two areas: LH & RH, each area have two
connectors (so 4 connectors in total not incl.)
Connector wire diameter: Ø2.0-2.5mm"
And as for the other question everyone else had
$690.00 plus GST... that was for a batch of 20!
Now, it came out a bit dear. So I'm not so sure about wether or not its worth it...
What do you guys reckon?
PostPosted: Mon Nov 23, 2009 7:45 pm
Ok, a couple of people mentioned that they were after re window demisters?
Well, it appears that buying kits is not as easy as it once was...
This is the only one I could find
http://cgi.ebay.com.au/UNIVERSAL-REAR-W ... 3ef56444f5
I fitted it the other week and it works a treat. When the glazier came to fit it, he was suprised that I managed to track one down.
So I thought I'd put it up. Hope it helps someone
PostPosted: Mon Nov 23, 2009 9:15 pm
Any pictures on your install? :D
1965 Morris Mini Deluxe - 998cc SC12
PostPosted: Mon Nov 23, 2009 9:28 pm
eww you got me there... I might have some photos still on the camera down in the shed,,, but I can take a photo of the finished job?
PostPosted: Mon Nov 23, 2009 9:47 pm
Yep, just the final result would be great. :D
PostPosted: Tue Nov 24, 2009 10:06 am
Here you go :)
Users browsing this forum: Bing [Bot], IndigoBlueCooperS and 84 guests
