It is currently Fri Aug 15, 2025 3:53 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 101, 102, 103, 104, 105, 106, 107 ... 568  Next
PostPosted: Mon Nov 23, 2009 3:15 pm
Nothing
PostPosted: Mon Nov 23, 2009 6:09 pm
picked up li-ute from the dress shop tonight with its new mini skirt looks good :lol:
PostPosted: Mon Nov 23, 2009 6:18 pm
After driving the AU Ford all week, I took the Mini to work.
F@#k it goes..... :P
PostPosted: Mon Nov 23, 2009 7:06 pm
I dusted mine.
Damn. I hate having too many cars!
PostPosted: Mon Nov 23, 2009 7:26 pm
Ok then show us some pics please AL
PostPosted: Mon Nov 23, 2009 7:40 pm
i will send it by phone, batteries need charging in the camera :cry:
PostPosted: Mon Nov 23, 2009 7:53 pm
Ok thanks mate
PostPosted: Mon Nov 23, 2009 8:05 pm
I paid a large some of money for the first half of my engine build!
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Mon Nov 23, 2009 8:17 pm
Finally took her out for a lil rap around town, its been 3 weeks since i last drove her, id forgotten how much fun they are :D. MINIS RULE
PostPosted: Mon Nov 23, 2009 8:18 pm
Changed a stuffed water pump, so i swore at my radiator cowl for 20mins!!!!
PostPosted: Tue Nov 24, 2009 8:11 am
nothing yet but im goin to be working on it all day so ill get back to you all :)
'94 Honda EG4 Civic. -Daily-
'95 Honda DC2 Integra
PostPosted: Thu Nov 26, 2009 9:08 pm
Good to see all of our minis are behaving so well, cause no one has done any work on a mini for a few days. :?
Well I dismantled my 1275 LS engine and gearbox over the past few evenings.
Cam has 621 stamped on the end? What does that mean?
Crank looks good 10/10.
Rod ends are a little stange, they have a big conter weight on them?
Pistons have a very big dish.
Gearbox is brilliant.
Now have to start a conversation with GR about engine specs for the Metro Turbo installation. And then drop all of the bits over to GR.
Next thing is to concentrate on the body, strip paint, sandblast edges and repair rusty bits.. :)
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Thu Nov 26, 2009 9:19 pm
621 is a Camtech cam. [edit] it's NOT a VP3, that one is a 619.
Timing 25/56-65/20.
lobe lift .264"/.266"
duration 261/265 degrees.
LCA 108 degrees
Rocker clearance .015"
RPM range 1500-6500.
If you are going to use those rods, I'd machine the big lumps off the caps then rebalance, and consider wedging the big journal crank.
Last edited by drmini in aust on Fri Nov 27, 2009 7:29 am, edited 2 times in total.
PostPosted: Thu Nov 26, 2009 9:31 pm
adjusted the rear drums.. hand brake works again!!
tim
PostPosted: Fri Nov 27, 2009 5:34 am
scrapped all the body deadener off the underside of the floor
doing it with a heat gun is waay easy :)
Users browsing this forum: No registered users and 224 guests
