It is currently Mon Aug 18, 2025 8:46 pm
PostPosted: Sun Nov 29, 2009 10:44 am
Hello people!
I'm going to use a rover handbrake setup in my deluxe, just wondering if I can get any rover owners to measure up the square bracket (the back one) that holds the handbrake ratchet up in the car?
I need its height off the tunnel, thickness, and width as a minimum.
Any help is greatly appreciated.
Thanks.
:D
PostPosted: Sun Nov 29, 2009 12:46 pm
Hope this helps a bit
A = 25mm
B = 50mm
C = 40mm
It is 1.6mm thick and is set back 138mm from cross member to front of bracket.
Cheers Pete
PostPosted: Sun Nov 29, 2009 6:53 pm
Pete you are a legend! :D
Thankyou very much!
PostPosted: Sun Nov 29, 2009 7:42 pm
No worries
Cheers Pete
PostPosted: Sun Nov 29, 2009 8:06 pm
If it's not too much to ask, don't suppose you can tell me roughly where the hole for the cable to go through the floor is relative to the bracket?
:D
PostPosted: Sun Nov 29, 2009 8:16 pm
I will have a look tomorrow when I get home from work .
Cheers Pete
Edit- Just went and measured it, from the bracket to the handbrake cable hole is 85mm.
Users browsing this forum: drmini in aust and 297 guests
