It is currently Fri Aug 15, 2025 1:50 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 104, 105, 106, 107, 108, 109, 110 ... 568  Next
PostPosted: Sat Dec 05, 2009 5:18 pm
pulled the dash out to get the voltage regulator out wpita i am begining to know my toy inside out only wheel bearings and cvs to go now
PostPosted: Sat Dec 05, 2009 5:36 pm
Mokesta how the hell did you get it up there??????????????
oh and i didnt do anything today :P
'94 Honda EG4 Civic. -Daily-
'95 Honda DC2 Integra
PostPosted: Sat Dec 05, 2009 6:23 pm
I've got 2 more end frames and 4 more shelf beams. Set them up near the floor then dragged her on while resting on some long planks. Then slid her forward and raised the beams behind. Then lifted and slid her backwards. Repeat for hours until she was 2.3 m above the floor, then slide her onto the top shelf and take away the spare beams.
Lucky I'm already on the waiting list for a hernia operation :roll:
BTW, those second hand pallet racks are the way forward with shed fit-out. Far more shelves for your $ than anything else. Just have to get Yellow Tounge flooring to make shelves.
M
PostPosted: Sat Dec 05, 2009 6:44 pm
I fanged it up the F3 to Gosford and got a couple of S/H windscreens. :P
Thanks, Maxi... :D
Then I dropped in on MiniDave..
Of course, it was pie time at PITS on the way back. Mmmmmmmmmmm, pies... 8)
PostPosted: Sat Dec 05, 2009 7:39 pm
Got the engine back in - all lined up and bolted in - 2 out of three engine steadies bolted in. Found the exhaust pipe touches the push button start :evil: Not as far down the track as I would have hoped but at least I can roll it onto the truck.
David L
PostPosted: Sun Dec 06, 2009 3:24 pm
drove it for part of the MITG drive.
got home and got given some window trims and the leyland blackbook of a friend of my old man.
PostPosted: Sun Dec 06, 2009 3:32 pm
I put in the replacement inner steering column I received. Easier than I thought!
PostPosted: Sun Dec 06, 2009 3:48 pm
Replaced a broken accelerator cable. 8)
PostPosted: Sun Dec 06, 2009 6:05 pm
stripped and cleaned my toyo rockers and buffered more bolts
PostPosted: Wed Dec 09, 2009 9:37 pm
Changed the oil, oil filter, and radiator fluid. Fixed the light switch that keeps popping off. Think I need to buy a new PCB?
PostPosted: Wed Dec 09, 2009 10:21 pm
Packing it all up ready to move it on Friday. - Didn't know I had so many bits not connected yet :roll:
David L
PostPosted: Thu Dec 10, 2009 7:02 am
Lowered it by 1 finger (it's hydro, hehe)
Aimed the headlights (sort-of)
Pumped the tyres up and went for a fang round the block. :P
PostPosted: Thu Dec 10, 2009 7:50 am
Gave it a hard push in the wet over my favourite mountain pass 8)
And when the adrenaline was gone, started to clean the twin HS4s.
PostPosted: Thu Dec 10, 2009 8:10 am
filled it full of body parts.. Bonnet, LH door, boot lid and a couple of wheels... all ready to get it moved up north
PostPosted: Thu Dec 10, 2009 8:11 am
Took out the front and rear windscreens yesterday..
Is the locking strip re-usable? I managed to remove one without breaking it.
