It is currently Thu Jul 31, 2025 6:42 am
 Post subject: slave cyl spring
PostPosted: Mon Dec 14, 2009 11:31 pm
gday all can any one tell me why this happens
i put that spring on the top of the operating lever to the bleed nip on the slave and then it doesent work i hafto take the spring off and bleed the cluch again then it will work again {never works real well }
PostPosted: Tue Dec 15, 2009 6:33 am
Mods rock!
Sounds like the slave cylinder is US.
PostPosted: Tue Dec 15, 2009 7:50 am
It 'could' just be an adjustment issue.
Try this and see what happens.
http://www.7ent.com/page.cfm?pageid=60
68 Mini
70 Moke
PostPosted: Tue Dec 15, 2009 4:13 pm
i dont have theese fig 2 items is this a problem ---1)--- Back-off the two large nuts at the lower end of the clutch arm to the end of their travel. :?
http://www.7ent.com/images2/tech_ezclutch_3.jpg
PostPosted: Tue Dec 15, 2009 4:20 pm
No, those nuts are really superfluous.
PostPosted: Tue Dec 15, 2009 5:46 pm
shhh dont tell every one i want my car to keep its weight advantage :)
well i think i might replace the slave ,but before i do can anyone tell me how much travel mine should have when i put my foot on the cluch :?:
PostPosted: Tue Dec 15, 2009 5:49 pm
It is also worthwhile checking for wear on the three clevis pins.
One either end of the clutch arm and one under the dash into the bottom of the master cylinder.
I have seen these badly worn stopping enough clutch arm travel.
68 Mini
70 Moke
PostPosted: Tue Dec 15, 2009 6:28 pm
Smarty wrote:
It is also worthwhile checking for wear on the clevis pin
yea some guy on here that drives a am blue clubby mentiond that pin was us about a month ago :roll:
PostPosted: Tue Dec 15, 2009 8:07 pm
Tomboss Breweros
I heard someone here has found a good one on the ront of his toolbox :wink:
kimini wrote:
Jimmyinamini wrote:
