It is currently Wed Aug 13, 2025 6:15 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 112, 113, 114, 115, 116, 117, 118 ... 568  Next
PostPosted: Fri Jan 08, 2010 12:35 pm
Going to change the other wheel bearing and hope to god thats the problem.
Simplify and add lightness
PostPosted: Fri Jan 08, 2010 7:48 pm
teh admin God
teh admin God
Well, technically I fail. But recently, I found out that I had a very bad leaking hose into my left carby. So much so that, when running, it was actually a constant stream of fuel leaking out, not just drops. So I got a new hose and fixed it. In the process I found that 2 of my manifold bolts were not at all screwed up!
Loose as BRO.
Sir Namibian CAMEL of MONGOLIA !!!
Vrilen Snyson Racing: Finding us all a Vrilen
Asparagus: Experience the versatility
PostPosted: Sun Jan 10, 2010 5:57 pm
NAV-MAN
I buffed 2-3 mm of the tread of the A008's. The fun and enjoyable way :twisted:
PostPosted: Sun Jan 10, 2010 6:20 pm
Continued to remove the underbody deadener and paint from under my current project.... very slowly :(
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Jan 10, 2010 6:24 pm
We dragged the project Moke up a steep ramp out of the garden, and the new owner took it away. :P
PostPosted: Sun Jan 10, 2010 8:15 pm
Drove the Mini to Summernats and had a look around
PostPosted: Sun Jan 10, 2010 8:22 pm
Mucking around with spacers in the rear wheels today. Need to get the roadworthy done.
Fixed wipers, washers.
Investigating tyres & spacers.
Now ordering parts for next weekends effort. Mirror, gear stick knob & brake drums...
mark.
PostPosted: Sun Jan 10, 2010 11:20 pm
Sanded, killed rust, did a little grinding, little bit of welding and some priming... I want my mini back together so I can drive the blooming thing.
PostPosted: Mon Jan 11, 2010 12:41 pm
Painted engine bits . . . and packed some other mini stuff for the move.
PostPosted: Mon Jan 11, 2010 1:38 pm
blocked back primer on the roof of the Mk 1 project car- bloody hot work in this weather.
anyway, I'll blame phat kat, following his dent removal tips.
photos soon..........................
PostPosted: Mon Jan 11, 2010 10:17 pm
Replaced rubber crosses they were all busted lol helped bro finish putting head back on car (blew head gaskit) tightened up wheel bearing on bro car as well
PostPosted: Tue Jan 12, 2010 12:00 am
I pulled my gemini starter motor apart because the bendix wasnt throwing out properly. I stuffed it with graphite power.. bobs ur aunty
blokeinamoke wrote:
PostPosted: Tue Jan 12, 2010 12:34 am
Strangely enough. I did some more rust repairs, this time on the boot. I was going to source a new one (thanks to all those who helped), but rejuvenated by the success I had with fixing my passenger side door I thought I would give it a go... Several hours later and it's now sitting in the shed all primered up next to all the other bits that are going to be painted, hopefully by the end of the week, or Sunday..
PostPosted: Tue Jan 12, 2010 9:34 am
This space for rent
Reinstalled the newly-rebuilt speedo and put the wooden dash back together. Took it for a spin and wow, for the first time I think ever I have an accurate speedo in a Mini! 8) (Well, accurate up to about 90 km/h.. over that and it gets a bit optimistic :lol:)
PostPosted: Fri Jan 15, 2010 7:47 pm
removed more paint and also the metal strips from under the side gutters.
Much easier with the car upside down.. :D
1969 Cooper "S"
1967 Mini Deluxe
Users browsing this forum: BBY755, Bing [Bot] and 299 guests
