It is currently Sat Aug 02, 2025 11:26 pm
PostPosted: Sat Jan 16, 2010 9:09 pm
Yeah thanks Doc, i'll have to pull my finger out and swap dizzy's over because when i originally tried it i couldn't believe how well it revved, i suppose it will be a trial and error thing until i get the timing where it needs to be.
Colin.
PostPosted: Sat Jan 16, 2010 9:14 pm
Aldon engrave the model number on the body of the dizzie. You'll find something like "AY-100" hand engraved on the body.
Unfortunately, they also offer a custom curve service - or used to. You could discuss your engine spec with them and they would build a custom curve - or at least they said they would. So there may be no way of knowing how your particular dizzie is set up....without running it on a dizzie machine obviously...
Despite providing the requested details i found the curve nothing like what my engine needed. It was no big deal to work out what was needed and to curve the dizzie to suit.
Cheers, Ian
PostPosted: Sat Jan 16, 2010 9:16 pm
Methyl Benzene was sold from SHELL servos
Benzol was sold from BP stations
Same end result - cars went better and exhausts smelt better!!!!
PostPosted: Sat Jan 16, 2010 9:23 pm
ahem....
Paint Thinners
"typical sample,, Toluene 60%,,, Acetone 30%,, Ethyl Alcohol 10%"
I know how i get my high octance kicks off 8)
BOO YAH :!:
