It is currently Thu Aug 14, 2025 8:09 am
PostPosted: Wed Jan 20, 2010 7:16 pm
I might see if I can use a press to open it up and examine the crack surface. If it has the good old tide marks of a classic fatigue failure, I will not be recommending that anyone rebuild old harmonic balancers :wink:
michael
PostPosted: Wed Jan 20, 2010 7:34 pm
It's only grey cast iron, so if you press into it you will get 2x 1/2 pieces- all the better to look at! :lol:
PostPosted: Wed Jan 20, 2010 10:17 pm
Mods rock!
mickmini wrote:
And GTmowog - like i said before, damper bolt was torqued correctly (using a Warren & Brown deflection beam wrench), loctited, no oil slinger or lock washer to collapse.
michael
Hey michael, sorry here mate but I suspect that you may have mis-understood my point. I have NO doubt that you assembled it correctly as per workshop manual etc.
Just the 'normal' harmonics produced in the crank can have an effect that may make fasteners screwed in to it loosen off.
PostPosted: Wed Jan 20, 2010 10:50 pm
oh I forgot to mention that it took a lot of effort to unscrew the bolt because of the loctite :lol:
PostPosted: Thu Jan 21, 2010 3:18 pm
Yer, it's bloody good stuff... 8) :P
PostPosted: Thu Jan 21, 2010 4:08 pm
When Tuffbond rebonded my damper they broke it getting it apart so they turned up another out of steel :mrgreen:
David L
PostPosted: Thu Jan 21, 2010 5:03 pm
Thinking about harmonics, vibrations, movement, etc...
How good a fit is the timing chain sprocket on the crank? (assuming you are running a chain)
And something for the real experts, could an aggressive camshaft and a slightly slack crank sprocket get angry enough to loosen/damage the harmonic balancer?
Could a belt drive reduce the harmonics? (could a single row chain do the same thing for a shorter time!)
I know that the early Cosworth DFV and the Repco 4 cam used to do nasty things to cam followers until Cosworth came up with a fancy damper in the gear train.
PostPosted: Thu Jan 21, 2010 5:25 pm
yours might last a bit longer then?
PostPosted: Thu Jan 21, 2010 5:27 pm
A better fit than the damper apparently. I checked that and there was absolutely no slack there.
Users browsing this forum: justminis and 206 guests
