It is currently Tue Jul 22, 2025 7:00 am
 Post subject: tacho + pulsar dizzy
PostPosted: Sun Feb 28, 2010 3:42 pm
how do you wire up a a tachometer to the pulsar dizzy, I just have a standard 3 gauge (clubman) cluster.
Thanks,
Leighton
PostPosted: Sun Feb 28, 2010 3:47 pm
I have used a Pulsar dizzy in a Clubby, I wired it as stock and it worked OK.
Can't remember if the tacho was early or later model though.
PostPosted: Sun Feb 28, 2010 3:54 pm
thanks doc, but what wires go where?
PostPosted: Sun Feb 28, 2010 4:08 pm
On a Clubby GT, the tacho is wired in series with the power lead to the coil
When fitting a Pulsar dizzy to it, the black/white goes to the coil [+] terminal.
The blue wire goes to the coil's [-] terminal. The wire between the coil [-] and dizzy is removed with the old dizzy.
It is years since I did it.
Pretty sure a Clubby S is the same setup, it would be helpful if Leyland had produced an AUSTRALIAN diagram for it. None of my manuals have one, including the Leyland Black Book.
Last edited by drmini in aust on Sun Feb 28, 2010 4:27 pm, edited 2 times in total.
PostPosted: Sun Feb 28, 2010 4:17 pm
Don't forget that there are two different types of tachos on Clubbies/Leyland Minis. :wink:
PostPosted: Sun Feb 28, 2010 4:18 pm
Post above edited after reading manual. :lol:
Yes there are 2 Clubby S tachos, but I think they are both inductive loop.
Early one had banana plugs on the back, as did the GT one.
