It is currently Sun Aug 17, 2025 3:37 pm
PostPosted: Sun Mar 21, 2010 4:08 pm
Matt it's a remote, keyed inside the box, not splined... :wink:
PostPosted: Sun Mar 21, 2010 4:13 pm
TheMiniMan wrote:
just thought that maybe when the pics were taken that it was moved inbetween the different pics,,,
Yes. When I was taking the photos I took a series of photos of the shift in every position. I just posted the clearest photo even though the shift is not in the normal neutral position, it is towards one side of the gate.
PostPosted: Sun Mar 21, 2010 4:59 pm
oops,,, of course,,, now i`m getting like my dad & forgetting silly stuff :-(
PostPosted: Sun Mar 21, 2010 8:44 pm
:D
Ok, so gear selector in neutral = knuckles ontop of the diff horizontaly aligned? That's good to know!
Another thing: I dismantled the 'U' shaped knuckel in the diff housing and found 4 rubber shims on the shaft. But then a 5th one fell out from somewhere... Can't figure out where it belongs...?
And I guess the diff side covers from a rod change fit on a remote too? Resp. are they any different? The diameter of the bush seems the same...
Cheers and thanks,
Jan
PostPosted: Sun Mar 21, 2010 8:51 pm
Mods rock!
Asphalt wrote:
:D
Cheers and thanks,
Jan
The left one is the same, the right one is different, a cover from a rod will go on a remote but not the other way.
PostPosted: Sun Mar 21, 2010 8:52 pm
Yep rodchange side covers will fit. Holes etc are the same.
re this linkage on top-
When you fit the female knuckle to the shift rod up through the diff, the ball at the bottom should be in line with the bottom one on the bellcrank, when it's in neutral and aligned in 3rd-4th gear plane.
the extra rubber washer may have been from outside,,,for the side of the pin at the end to insulate the steel washer from the diff housing (strane they attempt to fit rubber washers in an attempt to make it "anti rattle",,, on the most rattly gear-shift mech known to man kind)
& the roddy/potty type side covers (final drive covers) can be used yes, providing that you`re not using an "S" type diff & final drive couplings etc
PostPosted: Sun Mar 21, 2010 9:03 pm
Ok, thanks a lot guys!! :)
I'm going to use the good old trusty pot joints :)
Jan
PostPosted: Mon Mar 22, 2010 1:37 am
Hmmm... Just had a close look at this picture http://www.ausmini.com/forums/viewtopic ... 981#724981 & the ones posted here; looks like the aussis win again... My remote has no cover for the opening in the diff case where the 'U' shaped knuckle sits in... That's probably why it was so filled with dirt and cr*p... :?
PostPosted: Mon Mar 22, 2010 6:31 am
Jan,
Not all remote boxes here had these covers, but they do stop dirt and spare parts falling in there.
Just bent a bit of galvanized sheet up and cover the hole. A big pop rivet will do to hold it.
PostPosted: Mon Mar 22, 2010 7:46 am
That's what I had in mind. :) Grease it all up with lots of teflon grease and seal it as good as possible.
Users browsing this forum: No registered users and 390 guests
