It is currently Sat Aug 09, 2025 10:05 pm
 Post subject: another problem
PostPosted: Mon Mar 22, 2010 8:21 pm
the joys of miniing have presented me with another problem.. ive just got my a+ motor going in the car and ive got air bubbles blowing out front between the head and the block.. this means? (and yes i know its not good) what do i do :( stressed out now.. got grand prix in two days.. no sleep.. bloody minis..
Potato
PostPosted: Mon Mar 22, 2010 8:23 pm
Get some sleep. The Mini will still be there when you get back.
PostPosted: Mon Mar 22, 2010 8:26 pm
id still like to know whats wrong.. :( ive got no oil or water in the chambers...
Potato
PostPosted: Mon Mar 22, 2010 8:30 pm
mono-torque headgasket???
either way,,, sounds like the ehad has to come off if there`s water P1$$ing out between the block & the head
maybe a re-torque "could" fix it but usually it doesn`t
If the threads on the cyl-head studs/bolts have bottomed before pulling the head down enough then that`s a problem
...add some more flat washers
If there`s a dodgie head-gasket (monotorque or copper-- here we go again :-) ) then replace it
maybe there was a big piece of crap stuck under there that you didn`t see when you dropped the head on???
go get some sl;eep & fix it in the morning
PostPosted: Mon Mar 22, 2010 8:34 pm
concentrate on the GP and go to bed spotty
did you check the head & block was flat, does it have a new head gasket and the head studs correct length to the head
As morris said, get some sleep. its not your racecar, fix it next week.
Go to the GP and enjoy, and dont forget to wave!!
Have you got an AUSMINI sticker on the racecar?
PostPosted: Mon Mar 22, 2010 8:37 pm
Yeh....first things first... yer got races to win.
PostPosted: Mon Mar 22, 2010 8:39 pm
Maybe it is something simple like stretched head studs from a wrecking yard trying to start the motor when the cylinders have been full of water.
Nothing that a new set of con-rods and a full gasket kit won't fix.
(see if you get to sleep now! :mrgreen:)
PostPosted: Mon Mar 22, 2010 10:10 pm
If you have studs, make sure they are fully nipped up before you torque the nuts, otherwise they can work loose as soon as you start it up....
PostPosted: Tue Mar 23, 2010 12:15 pm
fixed (middle bolt was not right, replaced with correct one and shes all good)
but
im assuming my problem is incorrect carby on the motor, ive been trying to get it running with the 1.5 inch s.u that was on the 998 but it only runs with full choke and as soon as i take that off it stalls.. im going to get an hif44 but cant get one just now, am i correct in the not enough fuel statement?
Potato
PostPosted: Tue Mar 23, 2010 2:32 pm
Sounds like it to me... needa needle change! lower the main jet, wind it down, this will give more fuel!
I Have Hif44 and HS6's forsale... PM me if keen.
-Cam
IS NOW BACK ONLINE AFTER SOMETIME..... SORRY TO ALL, FOR NOT REPLYING TO PM'S!!
PostPosted: Tue Mar 23, 2010 8:30 pm
Dash pot fluid?
Sucking air through the throttle shaft?
carb not sealing on the manifold?
splits in hoses?
PostPosted: Tue Mar 23, 2010 10:36 pm
That's where my money is..................
PostPosted: Wed Mar 24, 2010 10:34 am
ok so after, different carby, new manifold, new dissy cap, new plugs, leads.. i still have the same issue, i know the fuel pump is working, i know the fuel lines are all good.. ive tried two coils... and still wont run under 2500 rpm and the choke must be on, when i hit the accelerator i get a big flat drop in revvs where if i left it open it would stall..
ive got no idea
do you?
Potato
PostPosted: Wed Mar 24, 2010 10:49 am
Got points? If so, check the gap- weird things happen if they close up or open up...
Users browsing this forum: Bing [Bot], trinube and 92 guests
