It is currently Fri Aug 08, 2025 10:23 pm
 Post subject: Broke wheel stud-nut.
PostPosted: Mon Mar 22, 2010 7:28 pm
he lads.
my superman strength, lol i broke a wheel stud on my 8.4 disk brakes.
i have a new one on order.
is there a how to? i have never replaced one, im not sue what to do, is there any tools i need?
can it be done on the car? or do i need to take the whole disk brake out to do it.
thanks.
PostPosted: Mon Mar 22, 2010 7:33 pm
Mods rock!
You'll need to take the drive flange off the disc. There are several different studs so I trust that you have ordered the correct one.
40ft/lb no more.
I did exactly the same thing on my 7.5" brakes a few weeks ago.
If 8.4" brakes are setup the same as the little ones then the studs are a piece of cake to replace. I just gently drifted the remains of the old stud out using a centre punch and put the new one in from the back. I then used a standard wheel nut to pull the new one all the way in and Bob's your uncle.
It's probably not a bad idea to put a small spray of WD40 on each of the studs before replacing the nuts.
edit - I just read GT Mowog's post. I didn't need to take the flange off mine, so maybe the bigger disks are different.
PostPosted: Mon Mar 22, 2010 7:35 pm
with 8.4 discs, you need to remove the road wheel, loosen the 3 bolts through the drive flange into the dic, take the big center nut off,,, & then tak the caliper off (2bolts) but you can leave the hose attached & rest the caliper onto a tin or block of some sort so you don`t stretch the hose
& then tak out the 4 bolts holding the flange to the rotor, take the flange to a vise & smack it out with a punch,,, smack the new one back in & whack it all back together
i have done it on the car by removing the caliper & taking the 4 drive flange bolts out & pushing the disc back away from the flange & with a bit of a fiddle & fart-arse & swearing you can get the old one out leaving the big center nut on so the flange is still attached to the CV , butt it`s a right pain in the butt
take the flange out & do it on the bench/vise , it`s much easier
cooper"S" ones are way easier,,,you can just smack em out & pry the new one back in
PostPosted: Mon Mar 22, 2010 7:37 pm
Oh well. Looks like another good reason to go for 7.5" disks :)
PostPosted: Mon Mar 22, 2010 7:40 pm
40ft/lb no more.
i ordered from lindsay, i would assume rover disk brakes would be all the same?
what is the difference.
i know 40ft i was told so many times :p my bad.
thanks matt, bit of fuffing around then! bah.
PostPosted: Mon Mar 22, 2010 7:48 pm
Nah ,,,it`s pretty easy & quick mate,,,
you`ll need an 1"&5/16ths socket for the big center(CV) nut tho,,, or a motha shifter
a 9/16ths spanner (or socket) for the caliper bolts ,,, easy
& a 9/16ths socket & breaker bar for the drive flange bolts,,,again pretty easy
& yes max tightness on both the drive flange bolts & the wheel nuts is actually 42lbs,,, but 40 is fine too :-)
I """ALWAYS"""" use a torque wrench on "ALL" wheel nuts !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
PostPosted: Mon Mar 22, 2010 7:51 pm
yep i have been told this many times!!! i think it's time i buy one.
PostPosted: Mon Mar 22, 2010 7:55 pm
ick,,, funny as this may sound,,, it`s probably more of a "Past-fatigue" that`s caused it,,, tyre shops are renowned for using big impact rattle guns on wheel nuts & most of em dont realise that the P!$$y litlle mini nuts need P!$$y little torque,,,so their big phat rattle guns just stretch the sh!t outa them
then you change a wheel & snappo,,,
that`s the usual scinerio anyways :-)
PostPosted: Mon Mar 22, 2010 8:27 pm
NAV-MAN
What Matt said, plus i like to make sure the threads are nice and clean too, that way you know how tight they really are
PostPosted: Mon Mar 22, 2010 8:31 pm
& add a little "dash" of copper-coat to the threads before fitting the nuts,,, makes em all nice next time :-)
PostPosted: Tue Mar 23, 2010 6:52 am
Just a thought but if you broke one and you are going to the effort of removing the flange why not replace all 4...
If ones broken due to abuse/fatigue/age etc. then its not unreasonable to assume the others may be weak/compromised too?
Personally I would go the whole hog and replace all studs on both sides to do the job properly and be sure... But I am a belts and braces kind of guy...
PostPosted: Tue Mar 23, 2010 10:58 pm
I agree. The remaining studs are probably approaching their 45th anniversary and close to retirement age. Lash out & replace the lot.
Users browsing this forum: 1071 S, Tezmini62 and 89 guests
