It is currently Fri Jul 18, 2025 7:18 pm
PostPosted: Fri Mar 12, 2010 6:27 pm
Mods rock!
nd, the outer sleeve it's attached to is pretty well impossible to get out whilst in the car, due to the thoughtful location of the exhaust system.
Actually, they do come out very easy. It's a bit like putting the bolts in the engine mounts.........no trouble at all... :wink:
PostPosted: Fri Mar 12, 2010 6:49 pm
they are a press fit... I leave em there and make a lurethane or steel bush to suit. :lol:
PostPosted: Fri Mar 12, 2010 8:52 pm
These coupling pins get so loose people put wire through them so they don't fall out (yes, they can and do...)
I have also seen them lock-wired in place.
me three . . . i have seen them lock-wired, self tapper in them, replced with a bolt . . . etc etc because the roll pin was coming out or had fallen out due to the wear of both the shaft and the coupling . . .
personally I like the rod change over the remote but they both have thier good and bad points.
PostPosted: Sat Mar 13, 2010 2:05 pm
Have had to go away for work for a couple of weeks, will let you know the outcome when I get back. Thanks for the tips.
PostPosted: Sat Mar 13, 2010 3:59 pm
For the un-intiated how can I tell the difference between rod/remote change?
PostPosted: Sat Mar 27, 2010 3:11 pm
I'm back and just checked the car.
Just to refresh the topic, the car had been sitting for a while, When I first drove it the gears weren't to bad to select, the more I drove it that day the harder it was to find gears and basically grinded or crunched when trying to find gears. End of the drive basically undriviable.
Checks as advised|
I just checked the linkages they appeared fine. When I go to put it in gear whilst running, will not engage just grind. If I try and start the car in gear with the clutch pedal depressed the car will lunge as if in gear, also then hard to get out of that gear. The clutch arm does travel quite a distance but am unsure if it has pressure.
Any help please.
PostPosted: Sun Mar 28, 2010 9:06 am
NAV-MAN
Sounds like the ball at the end of the clutch arm is broken. remove it and inspect it for wear and shape. Also take the time to check the clevis pin for wear as well.
It should look like
If the end is like this one then it is ok. But if it is straight or worn a fair bit it won't play well with the rest of the setup.
PostPosted: Sun Mar 28, 2010 10:36 am
Pulled the arm out and it is quite worn on the ball on oneside & the hole also looks worn.
PostPosted: Sun Mar 28, 2010 1:32 pm
Sometimes when the arm gets really worn they crack under the pivot point too, can be hard to see under all the goop that ends up down there, but that often accounts for the suddenly-my-clutch-is-not-working-so-good--Oop-it's-gone syndrome :P
Jacob
PostPosted: Sun Mar 28, 2010 1:53 pm
Don't have a spare, so when I locate one will try the easy fix first, if no luck will then take the flywheel cover off.
PostPosted: Sun Mar 28, 2010 3:56 pm
NAV-MAN
Clean and inspect the base of the clutch arm. as they crack there and flex when in use giving the same symptoms you describe and can happen as quickly as yours did, wear can be overcome with adjustment to an extent. i dont think that is the cause of his problem here, something is/has failed
PostPosted: Sun Mar 28, 2010 4:25 pm
So, you think that this worn arm may not be the problem. Any other possible suggestions.
Users browsing this forum: Bing [Bot] and 107 guests
