It is currently Fri Jul 18, 2025 5:28 pm
PostPosted: Wed Jun 09, 2004 10:59 pm
Gafmo
I have used Frank Kleinig at Giraween for a number of different types of vehicles, including the mini. He will definently find you horsepower. He has a distributor regraphing facility thare and is very good with webbers, not so sure about su's.
In saying that the last car I had in there would be 1996. I belive his sons run the business now.
The old dyno he had allegedly read low, howver my 1380 with webber, 11.2 to 1 compression and old 544 cam went in with 75hp and left with 86hp. The cheapest horsepower I ever found., and I belive fairly close to the mark as far as real world figures.
Give them a ring and discuss your needs, I have allways found them open and honest, and not out to make a fast buck. look in his workshop and there are allways heaps of cars there.
Master of the obvious - Prophet of the past
PostPosted: Wed Jun 09, 2004 11:07 pm
Bent S I found he was very truthfull to me with good service (which I like) he also mention that my dizzy needed remapping but I declined as it was not mine.
Maybe thats what is wrong with Morris.
Morris is booked in for next thursday for them to look at as Morris has sent me bald scratching a head
Frank use to race mini's some time ago and has passed on the business to his suns but frank still watches over. The reason I origanly went thier was that he does so much work on Formula V's (which I got to sit in a new one) and Historic Cars
Gamfo
in the Hills
PostPosted: Wed Jun 09, 2004 11:17 pm
Yeah he was really good at building the formula dak dak engines. In the eighties he used to build just about every engine in the field.
He also had a bit to do with formula brabham (holden) when it was introduced. ask him if he has still got his puke green UC torana, it had what was basically a formula brabham v6 in it and went like stink - a real sleeper.
PostPosted: Wed Jun 09, 2004 11:37 pm
Will do mate Puke Green LC what were they thinking
PostPosted: Thu Jun 10, 2004 12:03 am
U C Torana, the last of them (Thank god) LC was early shape.
PostPosted: Thu Jun 10, 2004 4:28 am
How much do you people pay for a dyno and a tune?
 Post subject: GREIG
PostPosted: Thu Jun 10, 2004 1:47 pm
I'd try Greg at Mini Classic in Ermington.
9874 7211 :wink:
Greig Malure - one fast Mini peddler...............
PostPosted: Sat Jun 12, 2004 7:58 am
MIke good question.
I'm going to answer this question for a friend down in ADL. I have only one at the moment but intend to get a number of other shops costing also.
One place I called on Friday charges
Skimming of a head $85
Bench Dyno $50Day
RR no does not do
Pocketing $150 (with the Engine Stripped)
Gearbox recond $200 to $2000 Deoenging on how huch work is required) yer ofcourse.
Previous RR $350
I have not mentioned which shops these r from as I'm not going to promot anywhere without experiance of thier work.
Hope this Helps
Gamfo
in the hills
PostPosted: Sat Jun 12, 2004 9:12 am
gaf, I think it'd $500 a day for the engine dyno (I can guess whose!), not 50. :wink:
It takes a while to set it up too, I've done it- it's not just a `drive in & spin the wheels' deal. But an engine dyno is still the best to find power, IMO.
<edit> Frank Kleinig has a scale of charges on his wall, but I can't remember how much. I think it was around $75 just to run it up?
PostPosted: Sat Jun 12, 2004 9:20 am
crap you are correct the Bench dyno was $550 and you are guess correctly I gave them a call the other day. And I mentioned your sign on name and knew you. Coolies
RR is from another shop I have been to and had it done Recomend. $370
He does have a price list and will give the a call today to update this section. Ihave had a couple of people ask me lately so Ill make a new Post for it.
gafmo
In the Hills
