It is currently Sat Jul 19, 2025 7:10 am
PostPosted: Thu Apr 01, 2010 10:05 pm
yea its about my only option now sady, thanks for all the advice tho guys :)
if i had my mini, i could of parked there!!
turbo 1100ccc engined 850 build & my blue deluxe
PostPosted: Thu Apr 01, 2010 10:08 pm
about 9:30 one night a few weeks ago I was fiddling around with my timing marks, and tried to use a little bit of wire to put some paint on the flywheel. I dropped the wire into the clutch housing :roll: gotta drive it to work the next morning, so off it came.... you do what you've gotta do
PostPosted: Thu Apr 01, 2010 10:12 pm
oh dam, thats about the bottom of bad luck, yea for me its gettin the time to do it between work and school, but easter holidays are up now so wil be able to get around to it :)
PostPosted: Sun Apr 04, 2010 11:19 pm
Well i have found the problem.......s
1) Clutch arm was bent so not enough travel was created to disengage the clutch
2) One of the holes in the master cylinder's piston was clogged, this not allowing the fluid to return, which i managed to fix.
Thanks for all the help guys, im only 16 so still learning a lot as i go :)
