It is currently Fri Aug 08, 2025 10:22 pm
PostPosted: Fri Apr 02, 2010 3:18 pm
Well after looking at JAM's 1098 (99H stroker) motor sitting in my garage for a couple of years since I bought it from Anton, the crank now has a new home.
It's now in Gafmo's `Morris' Mini K, after his missus busted the front web off the original crank. Luckily the rods and block are fine.
The -.010/-.010 crank only has around 2000 miles on it since Anton ground it, so I stuck the whole lot in- bearings, thrust washers and all.
It should be a goer again by Tuesday. :P
PostPosted: Fri Apr 02, 2010 8:16 pm
Its all together and was going to put it all in until we realized their was to much movement with the pot joints and the side covers :roll:.
Spent two hours cleaning up 2 remote change housings full of grease :lol:
This Crank should be a good one as its had minimal work done to it where the last one was +40 I think (which I will keep for reference and to brag my wife broke this one).
This has to be one of the cheapest rebuilds, Gasket set, Crank & bearings and Harmonic balancer. Yes their are a number of things I would have done but I also want my Van on the road also so time and money is divided but this crank will be the heart an soul of this engine :wink:
Users browsing this forum: 1071 S, Tezmini62 and 75 guests
