It is currently Mon Aug 04, 2025 3:23 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 138, 139, 140, 141, 142, 143, 144 ... 568  Next
PostPosted: Thu Apr 15, 2010 9:45 pm
Decided it was time to get back into it :P
Removed more of the Interior and RH Window and went Rust spotting.
EDIT: Updated thread in Members Mini Gallery
http://www.ausmini.com/forums/viewtopic.php?p=730244#730244
Dicko
PostPosted: Thu Apr 15, 2010 9:58 pm
walked towards it, looked at it, kept walking
PostPosted: Thu Apr 15, 2010 10:15 pm
Drove the 1360 to work today. The little bugger still flies. :P
PostPosted: Thu Apr 15, 2010 10:22 pm
Milatsmadmini
*clicks "like" button*
PostPosted: Fri Apr 16, 2010 6:20 pm
Started cleaning my freshly bought twin su's.
Looks like its going to take a while to get them looking how I want them to...
Alister
PostPosted: Fri Apr 16, 2010 7:10 pm
Put the new Cooper S pulley on the 1412's crank, and bolted the MED damper to it.
Set TDC with a dial gauge and marked the pulley.
Fitted the starter.
Tomorrow I'll prime the oil pump and crank it over with plugs out until it's got oil pressure. Then it's all ready to drop in. :P
PostPosted: Sat Apr 17, 2010 3:29 pm
Changed the oil from 25W50 to Penrite HPR50 40W-70, oil pressure is back up again when hot :D
Hopefully it should slow down the oil leaks in the gearbox too
1965 Morris Mini Deluxe - 998cc SC12
PostPosted: Sat Apr 17, 2010 3:40 pm
Pulled more of the Interior out and found nasty things :shock:
See post in Members Mini Gallery here http://www.ausmini.com/forums/viewtopic.php?p=730595#730595
PostPosted: Sat Apr 17, 2010 4:10 pm
Gave woody a sponge bath and a polish but I really need to change those front donuts !
PostPosted: Sat Apr 17, 2010 4:23 pm
changed the engine steady bushes to a different type that i got from mini king yesterday.
tightened the fanbelt, adjusted the brakes+bleed and gave it a bath all ready for tomorrow now
PostPosted: Sat Apr 17, 2010 5:42 pm
Finally got my drivers door handle/latch/lock and bits in and working fine! Was pretty stoked, til i started the passenger side.........................not so lucky with that one :evil: !
So for the firest time in a decade i can lock my drivers door............does it really matter that there's no window in it yet :lol: !
Cheers, Kim :-)
**purple '68 deluxe!**
***FINALLY wearing number plates----yeaaaaaah baby! ***
PostPosted: Sat Apr 17, 2010 5:53 pm
:lol: Bet your just waiting for the day you can park it in front of the Prince :lol:
Mike
PostPosted: Sat Apr 17, 2010 6:03 pm
Mike
:lol: i'd be happy to be able to park it anywhere right now Mike :lol: !!
and the prince is only 3 blocks from me, so at least i could push it there :D (or home if i had to!)
Cheers, Kim :-)
PostPosted: Sat Apr 17, 2010 7:00 pm
Good luck with that...
I bet in the middle of winter, you won't be able to get gears. The stuff is so thick then, it sticks the primary gear to the crank.
Happened to my son's Clubby, in Sydney.
If you must use Penrite (I used to.. :roll:) I'd stick to HPR40.
PostPosted: Sat Apr 17, 2010 7:09 pm
But probably not :shock:
Dicko
Users browsing this forum: Fritzie and 91 guests
