It is currently Sun Aug 03, 2025 6:48 am
PostPosted: Mon May 10, 2010 7:51 am
So I jumped in the Mini this morning and went straight through the seat. Sitting low in the mini is fun....but this is going too extreme.
I had a look, and the black rubber sheet / netting that is under has split right down the centre, theres about 1cm on one end that is holding it together.
Can this be replaced repaired ?
*I now know I can replace it, they sell them on Minispares UK site.
Or would I be better off putting up with the doona that I stuffed under my seat (yes..it works) & get myself a cobra seat ?
If I have to buy new seats, I don't want Rover ones, as they are probably just as expensive as some aftermarket ones.
PostPosted: Mon May 10, 2010 8:05 am
You can buy the new rubbers, but they are not that cheap.
Cheers Pete
http://www.minisport.com.au/prod232.htm
PostPosted: Mon May 10, 2010 8:08 am
Different to my Rover one, I will grab a picture when I can. But holy crap, $80 is a bit steep for a bit of bloody rubber.
*Added pic to original post, and made the description better than what I had.
Might end up getting some rubber matting from the local rubber place and do it myself.
PostPosted: Mon May 10, 2010 8:18 am
For $54 I am getting from from Minispares in the UK, delivered.
