It is currently Sun Aug 03, 2025 12:26 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 144, 145, 146, 147, 148, 149, 150 ... 568  Next
PostPosted: Sun May 09, 2010 8:56 pm
Got a complete Exhaust system today (Thanks again 69Cooper). Mocked up the head onto the block and put on the Weber Carby and Manifold with the extractors. The flanges on the inlet manifold are thinner than the extractors so I made some spacers and it all fits together nice and snug. Looks like it will sit in the engine bay without any mods which is good. New timing belt and seals for the timing kit were dropped off this evening. Off to get some valve stem seals from somewhere tomorrow then I can finish putting the thing back together and fired up..
PostPosted: Mon May 10, 2010 4:54 pm
nothing but thinking and dreaming. Lots of talking about them both as well!
mooo, I'm a pig!
PostPosted: Mon May 10, 2010 6:11 pm
Ok got my 4 pots bleed now, ITS BRILLIANT!!! Nose drops down ( Hydro car with front shocks) and stops super good!
PostPosted: Mon May 10, 2010 8:43 pm
Worked on the chook shed - finished the block foundation walls- as you may know from other posts this is Mini related as SWMBO has decreed the chook shed has to be finished before I'm allowed to work on the Mini again :roll:
David L
PostPosted: Mon May 10, 2010 8:47 pm
discovered my petrol tank looks new since i spray painted it, air compressor arrived(finally), started taking out rear subframe
PostPosted: Mon May 10, 2010 9:32 pm
Took off that stupid alloy rad that i bought off ebay and put back the trusty old one that worked fine and it still works fine although now it has a nice new coat of paint. I can't sell anybody the alloy one has i put a brick through it. Temper temper. :lol:
It might only have half the engine but its got 4 times the handling...............
PostPosted: Mon May 10, 2010 9:38 pm
maybe you could sell the brick its obviosly realy strong :P
PostPosted: Mon May 10, 2010 9:43 pm
discoverd that my thermo housing will always leak unless i use silicone as there is a 1mm hole in the head through to the thred where the bolt goes ,
choped up my stock intake manifold sos i can fit the extractors i still need to rebuild the twin carbs but ge it looks sweet with the twin manifold sitting there..,,..
PostPosted: Mon May 10, 2010 10:11 pm
Almost finished welding the new rear beaver onto my project and had 2 holes to plug and ran out of wire in the MIG. :(
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue May 11, 2010 11:02 pm
Well after sorting out the drama of me being a complete nonce and losing the collets and valve spring retaining caps. I got the head on and....... The engine back in the car.
More bits to go in tomorrow... After I put the shed back together.
PostPosted: Wed May 12, 2010 2:55 pm
Drive shafts back in, why oh why didn't they make it so that the potjoint would fit through the subframe on 76 Clubmans.. Didn't have my morning coffee so I ended up trying to fit the Left hand side to the right.. Couldn't figure out why it wasn't long enough, figured it out pretty quick though, it's official I'm mentally deficient without my first coffee... Oh well live and learn. :)
PostPosted: Thu May 13, 2010 12:09 am
Got driveline in, put new ties on the boots, since I had to pull them apart to get them in. Cleaned up the Rod change, put some grease inside it on the moving parts, sanded back and painted the gear lever, painted head. Also fitted exhaust headers and inlet manifold with Weber. Hopefully it works as I had to shim out flange on the inlet because the metal is a bit thinner than the flange on the header pipes. Colour matched the rocker cover to the bodywork. Just got to put in the Radiator, a battery and the wiring and I can start it. After that it's just all the fiddly stuff. Connect up the clutch lines. Do the interior, buy some new tyres for the Contessas and put the windows back in..
Updated engine pic in the Gallery.....
PostPosted: Fri May 14, 2010 12:09 am
Radiator in and all plumbed up. I haven't put the heater back in yet so I have re-routed the plumbing for that. Might try and find some sort of electric solution for a demister for a bit more room up front. Cranked it over on the starter motor and got the oil flowing. Applied some brush on sound deadener to the boot area and along the underneath of the sills and under the front wheel arches.
Might be able to have her started tomorrow. :D
PostPosted: Fri May 14, 2010 1:52 am
MiniKit wrote:
... Hopefully it works as I had to shim out flange on the inlet because the metal is a bit thinner than the flange on the header pipes...
In a bunch of stuff I got with my mini there were some of the thick washers for the exhaust/inlet attachment and they had been ground down on one half so it was stepped. Obviously had the same issue as you. This seemed like quite an easy fix, provided the right amount of material was ground away.
PostPosted: Sat May 15, 2010 12:33 am
Couldn't get weber and the intake manifold to seal properly, so I chopped up the original SU mainifold so it would work with the extractors and put that back on, pity though the Weber looked so much cooler.
Don't have the wiring back in the car yet so I hot wired it, after I fixed a short in the Distributor and put on a new coil I managed to get a good spark. Poured a bit of fuel down the carby, and it fired for a second. Still have to set the timing properly but it should be a goer. :lol:
