It is currently Mon Jul 21, 2025 11:42 am
PostPosted: Sat Mar 26, 2005 9:33 pm
Yep................ Throwout Stop and Lock Nut :shock:
Questions regarding these missing peices of the puzzle........
1. What affect does not having this do to clutch adjustment/working ability?
2. It says in the manual to set the adjustable stop to 1.524mm (0.060") from the operating lever, does anyone's settings differ from this factory setting?
2. Does anyone up here in SE QLD have one i can purchase off them??
Also, am missing the release lever spring, so if anyone has one of those as well :oops: .
Steve
I got nuthin......................
PostPosted: Sat Mar 26, 2005 9:40 pm
the plate on that flyweel timing hole thing is missing
PostPosted: Sat Mar 26, 2005 9:42 pm
That was removed today................ no stress regarding that issue :oops:
PostPosted: Sat Mar 26, 2005 9:50 pm
yikes...did they fall off? :shock:
PostPosted: Sat Mar 26, 2005 9:53 pm
Anton................ the disturbing thing is i only noticed this afternoon :shock: i removed the brake booster late yesterday............ so dunno how long it has been missing for, as i haven't really been able too see it very well before :oops:
Damn i'm such a newbie :oops:
PostPosted: Sat Mar 26, 2005 10:14 pm
They only stop your clutch from "overthrowing" (they are called "clutch overthrow stop nuts" from memory.....)
Not a problem if your clutch is set up even close to right.....
I never knew you needed them until i got a haynes manual (about 3 years after getting the car...) and mine had none....
Dont sweat it....
J
PostPosted: Sat Mar 26, 2005 10:18 pm
Steve, i have them all here in stock if you havn`t got them allready
Both the nuts & the spring are vital for correct clutch opperation,,,you really don`t want to see what happens if you have a problem with the clutch & these nuts aren`t fitted & set correctly,,,do the words, """Broken main bearing cap""" sound very nice????????
yes, if these nuts aren`t fitted & set correctly, all that`s needed is a bit of a problem with the clutch & it can """OVER THROW""" & when that happens, the pressure of the clutch works directly onto the crank thrusts working on the centre main bearing cap, enevitably fatigueing it & busting it off...& yes i`ve seen the results,,,Not Pretty
everyone should make sure that they have them fitted & set correctly,,,that`s what they`re there for & that`s what they`re called,,,"OVER THROW" nuts,,,should really be named """ANTI OVER THROW NUTS"""
I know of quite a few so called "mini specialists" that don`t bother to fit them claiming that they`re not needed & ,,,well,,,they may very well find out how wrong they are :-)
PostPosted: Sun Mar 27, 2005 6:18 am
You are right Matt, as usual, :lol: but they are the LAST thing to adjust, after you are happy with the pedal height etc.
The number of times I see them screwed too far in and people wonder why their clutch don't throw out... :shock:
BTW, real early 850 Minis never had them- not even a thread sticking out there! :lol:
PostPosted: Sun Mar 27, 2005 9:06 am
Matt.............. you open for business on Monday (if i come over with a few certain cans 8) ) if so i will be there in the morning :D
 Post subject: clutch
PostPosted: Sun Mar 27, 2005 11:02 am
im missing that thingymebob too.
ive had lots of problems with my clutch....now i think ive got it right but still have problems with it going into reveres once its been driving for some time.
allways crunchs like im not putting the clutch in all the way normal gear changing is ok just reverse....any idears about this...will get link to replace this next week as they took it of....i say if some guy made the engine with it on it should stay there...
