Steve, i have them all here in stock if you havn`t got them allready
Both the nuts & the spring are vital for correct clutch opperation,,,you really don`t want to see what happens if you have a problem with the clutch & these nuts aren`t fitted & set correctly,,,do the words, """Broken main bearing cap""" sound very nice????????
yes, if these nuts aren`t fitted & set correctly, all that`s needed is a bit of a problem with the clutch & it can """OVER THROW""" & when that happens, the pressure of the clutch works directly onto the crank thrusts working on the centre main bearing cap, enevitably fatigueing it & busting it off...& yes i`ve seen the results,,,Not Pretty
everyone should make sure that they have them fitted & set correctly,,,that`s what they`re there for & that`s what they`re called,,,"OVER THROW" nuts,,,should really be named """ANTI OVER THROW NUTS"""
I know of quite a few so called "mini specialists" that don`t bother to fit them claiming that they`re not needed & ,,,well,,,they may very well find out how wrong they are
