It is currently Sat Aug 02, 2025 8:43 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 147, 148, 149, 150, 151, 152, 153 ... 568  Next
PostPosted: Tue May 18, 2010 10:36 pm
I put my trigger wheel, harmonic balancer, engine mount bracket, radiator etc. etc. back in and it's all perfect again!
:D
and shoosh Aaron - I was going to ask for those tyres!
PostPosted: Wed May 19, 2010 8:48 am
I am home ill with the flu(isolation) so went and cleaned the wiring off in the mini. Prepping the engine bay for some paint and replaced the engine hoist hydraulic ram - I am back in business!!
Today - rebuilding the calipers...fun fun fun :D
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Wed May 19, 2010 9:32 am
I finally made up and installed my front door cards. I've been meaning to do it since the 2008 mini muster :oops:
I also re-did the check straps :)
PostPosted: Wed May 19, 2010 10:09 am
^^^^ look good :wink:
David L
PostPosted: Wed May 19, 2010 9:20 pm
that looks Great 8)
PostPosted: Wed May 19, 2010 9:23 pm
they look good man, can you make me a set in red please - ok thanks! :D
how do you pull the door shut without door pokets looks good though
PostPosted: Wed May 19, 2010 9:37 pm
Well the window should already be wound down due to the intense heat that comes along with a mini, so just grab the window frame :D
You're so square
Baby I don't care
PostPosted: Thu May 20, 2010 10:22 am
Isn't that why all the quarter window things are broken?
They look great.
I got my file out and filed my already painted door lock holes to hold some ndl22a laser locks. Pulled all the locking stuff out and it all works a charm now. Need one more part (the metal locking plate that goes on the back) and I will be happy as a clam. Will cut some up on the weekend.
PostPosted: Thu May 20, 2010 6:19 pm
jimmyinamini wrote:
how do you pull the door shut without door pockets
Yeah it's a bit challenging sometimes, generally I use the quarter window catches or the open window. I use to have Camira door arm rests with handles in them but they don't look good enough now :roll: .
PostPosted: Fri May 21, 2010 5:23 pm
finished building the driveshafts, double checked my triple checked assembly of the flywheel/clutch.
played with the harmonic balancer to ensure it all fits like it should.
measured old primary gear end float, ewww definatley replace it all with new parts :lol:
http://www.ausmini.com/forums/viewtopic ... 7&start=75
PostPosted: Fri May 21, 2010 7:05 pm
plnk slip woohoo
ook!
69 mini k
PostPosted: Fri May 21, 2010 7:08 pm
Took mine for probably its last run before the 1412 transplant. :P
PostPosted: Fri May 21, 2010 7:27 pm
just fit my new s/hand wiper motor works great :D
PostPosted: Fri May 21, 2010 9:53 pm
After trying to get Hetty going for five nights in a row, reading every post to do with setting static timing I've not been having much luck because my brain has been bobbing around in a pool of mucus (I's gots the flu). :cry:
I am finally well enough and my brain is finally functioning that I read through everything again and it made sense. Pulled everything apart (again) reset everything to where it is supposed to be, I squirted some "Start ya Bastard" down the carby and turned her over..... Bare in mind however that the full exhaust system is not on yet... Pop Pop Pop she went with beautiful blue flames beltching from the extractors. I thought to myself "Perhaps doing this on the carpet in the shed isn't such a good idea". :shock:
I turned the lights off and went inside beer in hand..
She can be put back together tomorrow... :)
Users browsing this forum: s-c1293 and 99 guests
