It is currently Sat Jul 19, 2025 3:14 pm
 Post subject: exhaust & carby setup?
PostPosted: Fri May 21, 2010 12:19 pm
Interested in getting a little more out of my stock 1275 without really taking it apart just yet...
Will going down this track help?
Currently a 1 1/2" SU (stndrd inlet manifold) 2" exhaust lukey muffler (extractors ..not sure which kind)
Was thinking a 1 3/4" SU & larger inlet mnifold. Also a better set of extrctors and
1 1/2" exhaust (hotdog running to muffler)
Which extractors should i track down?
any suggestions?
PostPosted: Fri May 21, 2010 12:46 pm
any suggestions?
The carb is the first thing to change. 1 3/4" is the way to go
your current extractors are probably fine, the jury is out on whether 1275's like 2" or 1 3/4" better
PostPosted: Fri May 21, 2010 12:50 pm
1.75" SU on a good manifold with 1.75" exhaust. Will be great on a stock 1275 right through to the hottest road engine.
PostPosted: Fri May 21, 2010 1:23 pm
Sounds good 1 3/4 su x 1 3/4 exhaust & better manifold.
PostPosted: Fri May 21, 2010 2:42 pm
Fiji you will need to decide if you want a HS6 with manual choke or a later HIF model with autochoke.
Alec
PostPosted: Fri May 21, 2010 9:00 pm
with a 1275 I would have three choices. HS6 HIff44 (auto Choke not needed) or Dellorto 45. All need to be Tuned and adjusted.
One thing I will ensure is to get the Carb to manifold to Head ports "Matched"
Exhaust I would keep as a number of people on here have good HP with a 2"
PostPosted: Fri May 21, 2010 10:45 pm
Funny u mention that I have a 42mm delorto / manifold sitting on my bench.fuel economy springs to mind when I think of using it
PostPosted: Sat May 22, 2010 2:29 am
Milatsmadmini
and thats where we differ my friend... i think delorto, i think induction sound....mmmmmmm :P
PostPosted: Sat May 22, 2010 8:05 am
Properly jetted (a little leaner for road use), the economy isn't too bad.
I run a 45 Dellorto with 38mm chokes in it (but I'm fitting 36s in for the 1412).
PostPosted: Sat May 22, 2010 9:02 am
Looks likeI might have a sit down think about his a bit today and find out what chokes are in it at the moment.
Anyone had any luck with delorto tuning with out loading the car on a dyno?i
PostPosted: Sat May 22, 2010 9:54 am
Yes. I went and borrowed GR's portable A/F ratio meter, then went for a drive. 8)
Users browsing this forum: No registered users and 63 guests
