MiniKit wrote:
After trying to get Hetty going for five nights in a row, reading every post to do with setting static timing I've not been having much luck because my brain has been bobbing around in a pool of mucus (I's gots the flu).
I am finally well enough and my brain is finally functioning that I read through everything again and it made sense. Pulled everything apart (again) reset everything to where it is supposed to be, I squirted some "Start ya Bastard" down the carby and turned her over..... Bare in mind however that the full exhaust system is not on yet... Pop Pop Pop she went with beautiful blue flames beltching from the extractors. I thought to myself "Perhaps doing this on the carpet in the shed isn't such a good idea".
I turned the lights off and went inside beer in hand..
She can be put back together tomorrow...
Should have started not just popped, it sounds like your dizzy is 180° out.
If you line up the timing marks, then fit the dizzy driveshaft in as per the manual's picture, it is 180° out.
Why?
Because when the timing dots are aligned, yes it is at TDC, but firing on #4, not #1.
Every A series is like this- you need to turn the motor over 1 turn before fitting the dizzy shaft.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
