It is currently Thu Aug 14, 2025 3:28 am
 Post subject: Roll Cage Material
PostPosted: Wed Jun 02, 2010 2:34 pm
Hey guys
Trying to track down where to buy some tube for a roll cage from ..
im after some 44mm CDS tube and 38mm CDS tube but most of the normal steel suppliers dont stock ...
So i wanna know where to get it ...
Im in Adelaide and there are a few places that do thier own roll cages, so they are obviously getting it from a stockist .. And i wanna know who
Any help would be great
Thanks Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Wed Jun 02, 2010 2:53 pm
High heel ninja
Do you have Blackwoods or One steel in Adelaide? Should be able to get it from them.
Doogie
PostPosted: Wed Jun 02, 2010 10:09 pm
Here you go Bean try these you will have to buy a full 6.1m length and probably a minimum of a round $150 worth
http://www.atlasmetals.com.au/Adelaide.asp
or
http://www.vanleeuwen.com/en/worldwide.aspx?region=AUS&opco=1831
4efte powered Clubman
supercharged 998 race car
PostPosted: Thu Jun 03, 2010 8:01 am
It's not made in Australia. Canadians make it.
Funny how CAMS wont allow the stuff we make here be used for roll cages anymore. It was good enough for Dick Johnson when he went off in his Greens Tuf Falcon.
PostPosted: Thu Jun 03, 2010 8:03 am
Cheers Ben ..
Atlas dont do the right grade of tube and dont know where to find it ..
so i will give Van leeuwen a go today ...
Cheers Beanie
HOTBRICKS
'65 NCF MINI.....
PostPosted: Thu Jun 03, 2010 11:35 am
That's CAMS for you. :roll:
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Thu Jun 03, 2010 6:16 pm
If you had looked closely at that cage after the crash you would not use it either. It should not have failed like it did.
I don't agree with much that CAMS does but I have seen a lot of aluminium roll cages fail when they shouldn't.
PostPosted: Thu Jun 03, 2010 6:25 pm
CAMS copy the FIA who are basically French so they want a French std and that's why the (french) Canadians make it.
Australian steel should be allowed IMO.
M
PostPosted: Fri Jun 04, 2010 9:12 am
Beanie
If all else fails, ask Walker Chassis at Houghton if you can buy some from them. You may just get stung with their mark up....
1964 Morris "Cooper S" Group Nb Racer
1965 Morris 850
ex 1967 Morris Cooper S
ex 1969 Morris Van (Rover SPI running gear)
Users browsing this forum: No registered users and 181 guests
