It is currently Sun Aug 17, 2025 3:45 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Jun 04, 2010 3:30 pm
AJ wrote:
None of my minis are even close to that , so it would have to be a very very much modified mini to even go under 10 seconds .....It would either have to have extensive modifications , an engine transplant or setup for drag racing , which makes most unsuitable for road use anyway ....... dream on
I know I shouldn't, and you definitely didn't mean to offend, but I take offence to that... my MK2 isn't extensively modified in the engine department, I built it myself and there is nothing particularly out of the ordinary in it. It's a very streetable car
In fact, this very morning I was testing the air fuel ratio, and confirmed that it is seriously lean at wide open throttle.
Coupled with that is that I use bridgestone SF226 tyres, which are definitely not known for their grip....
so here - I datalogged the RPM through my ignition, calculated the speed given the gear ratios and charted it. I launched at about 3700rpm which was probably a bit much...
edit: the dips in the chart are because it was based on RPM, not wheel speed, so when I changed gear the RPM dropped. It was on a slight uphill also
edit: bum - Mick gave me the wrong gear ratios, makes it a shade over 11.3 seconds, but I stand by what I said, 10 seconds isn't that hard
PostPosted: Fri Jun 04, 2010 4:19 pm
Supercharged
0-60mph taken from modern motor tests
850: 21sec may 1961
997 Cooper: 16sec jan 1963
deluxe: 21.1sec may 1965
AJB44B monte carlo mini: 8.2sec may 1965
1275 cooper S: 11.2sec jan 1966
1100cc K: 18.6sec jun 1969
1100 clubman: 18sec oct 1971
1275 GT: 12.3sec oct 1971
it wouldnt take much to get a 1275 car under 10 seconds.
my mini is faster than my colt ralliart and stuweys polo gti which are both 8 seconds 0-100kph according to wheels jan 2008
PostPosted: Fri Jun 04, 2010 4:26 pm
Fiji wrote:
What are some really quick ... Even pretty impressive mini 0-60 kph times?
Mearcat wrote:
Hanra wrote:
Once again, are we discussing 0-60kph or 0-60mph?
Given this is ausmini.com and everybody who has posted is from Australia, I think we can pretty safely assume it's kph.
Super-mini wrote:
0-60 mph taken from modern motor tests
850: 21sec may 1961
This just confuses the situation once again....
AJ wrote:
My WRX does it in 4.9 seconds , basically standard with a few minor mods .
I would have expected it to be 0-60kph also as the original post stated.
Surely a WRX can get to 60kph faster then 4.9sec's?
PostPosted: Fri Jun 04, 2010 4:32 pm
Supercharged
roundnose speedo in mph, all the mini tests in mph, 0-60 = mph
who the hell times 0-37.5mph? you'd have to be pretty sad to quote 0-60kph runs.
PostPosted: Fri Jun 04, 2010 4:34 pm
Fiji was also referring to Top Gear, who quote 0-60mph times.
This roughly equates to 0-100kph which is a standard performance indicator.
The modded WRX would do 0-100kph in under 5 seconds.
0-60kph figures are not readily available for most cars, and only really give you an indication of how good the driver can launch the car rather than the performance of the car itself.
PostPosted: Fri Jun 04, 2010 4:50 pm
Soz...but it did make you feel pretty fast for a few minutes there :P
PostPosted: Fri Jun 04, 2010 5:37 pm
850: 21sec may 1961
Its 0-100 kph
PostPosted: Fri Jun 04, 2010 6:21 pm
GPS logging at Oran Park showed my Nb Car 0-100kph Race start @ 7.9 seconds....
.. and I'm one of the slower minis...
1275 +30, std en40b crank, points
Weber + PORTED head + AvGas. (Compression ratio ? high)
3 Sync SCCR gearbox / 3.9 diff (Quaife)
Yoko A032R
745Kg (incl driver)
(haven't exrtacted data from other events)
PostPosted: Fri Jun 04, 2010 11:40 pm
Hanra wrote:
850: 21sec may 1961
AJ wrote:
Its 0-100 kph
Well Im just reading the original poster wrote.....? To me, KPH means kilometres per hour? Zero to sixty kilometres per hour???
I thought it was a little odd to....?
PostPosted: Sat Jun 05, 2010 10:24 am
you're just going to have to accept that he was confused when he made that post - this thread is about 0-60 mph, or 0-100kph
move on
Users browsing this forum: No registered users and 367 guests
