It is currently Sat Aug 02, 2025 12:12 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 153, 154, 155, 156, 157, 158, 159 ... 568  Next
PostPosted: Sun Jun 06, 2010 11:01 pm
Ongoing work of re-trimming the rear of Hetty..
The new Vinyl has been layed over the old to follow the contours of the original so I can now add an accent colour where the original fitted. Not perfect but much better than the spray painted crud that was on there before. :)
Also refitted the bonnet and bonnet latch..
She should be mostly water resistant now on the inside.. ROFL..... :D
PostPosted: Sun Jun 06, 2010 11:42 pm
I droped off my 850 van sliding window doors to the paint stripper man to have them plastic bead blasted. And I fitted the rover wiper motor to the clubbie 1/2 cut never ending project mini. And I put 2 1100 blocks in the boot of the car to take to the machine shop tomorrow.
Have a Nice Day.
PostPosted: Sun Jun 06, 2010 11:47 pm
When we had Barney with the twin HS4s and #6 needles, it had what felt like a lean spot just above idle. I was running 10W/40 motor oil in the dampers.
GR and I took it for a run up the road with his A/F meter, and found it was actually too RICH there, not lean. Just for fun we took the dampers right out, and the mixture cleared up. So I went home and tipped the oil out. Ran it dry like this for all summer and autumn, no probs.
I did subsequently put ATF in it during winter, as it was tending to be lean. Typical SU.... :lol:
Hehe - a damperless SU works nice, doesn't it? ;) The only downer on my carb is that it doesn't like to start very well, when cold.
 Post subject: Enough for one day!
PostPosted: Mon Jun 07, 2010 11:24 am
Engine out of donor car yesterday, not today.....and it really took me a bit longer than one day but she finally came out yesterday!
I would like to put a photo up...can anyone tell me how?
PostPosted: Mon Jun 07, 2010 11:36 am
Give Ash some flowers Nick .
The easiest way is to follow this URL.
PostPosted: Mon Jun 07, 2010 12:41 pm
simon k wrote:
jb007 wrote:
Put Kyaba front shocks on my hydro. Hopefully will stop car doing wheelstands when I take off from the lights!
competition bump stops at the back will help too
Will look at this after I get it back on the road and registered, running out of money! Do front competition bump stops help also?
PostPosted: Mon Jun 07, 2010 1:32 pm
No but the rear ones do make a difference.
Im guessing you have Std hydro bags in your car as the Coopers S silver band bags are much firmer. I find the front of my Cooper S does not lift as high as the Std mini deluxe.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Jun 07, 2010 4:17 pm
Thanks, yes, I have std bags. :oops:
I think I'll order some front & rear comp bump stops... here goes the credit card again! :roll:
PostPosted: Mon Jun 07, 2010 4:41 pm
I've only had rears fitted, but you might find that the fronts simply get demolished by all the load put on them continuously from the weight of the engine and the diving under brakes. Keep the old bumpstops near to hand in case you need to change them out.
PostPosted: Mon Jun 07, 2010 4:51 pm
Thanks Mick. I've just ordered both sets from my favorite supplier :wink: ... maybe I should pump the suspension a bit higher? Only joking. :)
Jim
PostPosted: Mon Jun 07, 2010 4:56 pm
If you do I have one or two spare hydro bags stashed away over here :P
PostPosted: Mon Jun 07, 2010 5:06 pm
Good to know, they are getting quite rare (working ones) now.
PostPosted: Mon Jun 07, 2010 8:11 pm
I had both Front & Rear comp Bumper stops fitted to a Hydro. The front got smashed and put the normal ones back on where the Rears are still doing their job perfectly
PostPosted: Mon Jun 07, 2010 8:47 pm
Comp front ones are too high unless you are going offroad. They jack the car high, you will have positive camber + understeer.
I use stock front bumpstops and comp rears, it sits level and handles great.
I run std Pedders shocks on the front.
PostPosted: Mon Jun 07, 2010 8:56 pm
Thanks for the heads up gafmo & drmini. Since I have ordered the front ones as well as the rears, I will have to put the front ones on Ebay when they arrive.
I definitely don't want to make the ride any harder. :D
Users browsing this forum: Barkfast and 81 guests
