It is currently Tue Jul 29, 2025 12:58 am
 Post subject: y do they fit
PostPosted: Tue Jun 15, 2010 9:34 pm
ok guys got a set of 7.5inch disk brakes they went on and they fit under stock standard rims disks have not been machined or anything but on other stock rims they dont fit ???? mine havent been modified at all any thoughts on this
PostPosted: Tue Jun 15, 2010 9:49 pm
different standard rims maybe.
PostPosted: Tue Jun 15, 2010 9:50 pm
they r stock steel rims
PostPosted: Tue Jun 15, 2010 10:08 pm
Are the calipers on?
Image Image
PostPosted: Tue Jun 15, 2010 10:13 pm
yep all bolted up
PostPosted: Tue Jun 15, 2010 10:44 pm
There are 2 or 3 different calipers:
Original Lockheed, fitted to Cooper S and GT
AP recent ones (maybe are same as Lockheed, I'm not 100% certain)
Unmarked recent ones
And there are 3 different 3.5x10 wheels:
original thin centre (1961), rivetted
thicker centre, rivetted
thicker centre, spot welded.
Some combinations just clear and some don't.
PostPosted: Wed Jun 16, 2010 12:42 am
the brakes are the Original Lockheed, fitted to Cooper S and GT ones and I suspect with your rims they only just clear?
PostPosted: Fri Jun 18, 2010 8:22 pm
S brakes fit under S wheels.
Other people have different opinions but none of my standard wheels will turn when fitted over S brakes..
Cheers, Ian
PostPosted: Fri Jun 18, 2010 8:24 pm
Cheers, Ian
They also fit fine under Clubby S wheels (which are 4.5Jx10, same offset & rim dimensions as Cooper S wheels).
Users browsing this forum: No registered users and 70 guests
