It is currently Sat Aug 02, 2025 12:12 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 158, 159, 160, 161, 162, 163, 164 ... 568  Next
PostPosted: Sun Jun 20, 2010 7:11 pm
Removed more paint.
Found more dodgy repairs - LHF Pillar :shock:
Removed the Seam Covers - Quite clean underneath :D
Removed the Hood Lining and side trims.
Removed the rear Wiring Harness.
Dicko
PostPosted: Sun Jun 20, 2010 9:04 pm
Replaced the dodgy looking strand of wire that was used for the main charging wire from the old alternator to the solenoid with a nice new fresh piece of 50amp cable. Still have red light on dash though :cry: . Cleaned every single earth I could find on the vehicle. Went for a hoon around the 'burbs, had oodles of fun doing it, that cheered me up.. :twisted:
PostPosted: Sun Jun 20, 2010 9:28 pm
I cleaned up my freshly beed blasted doors and painted some rust converter around the seems on the insides & in the drain channel under the sliding windows. I will spray some etch primer on them tomorrow, if the weather is warm enough.
Have a Nice Day.
PostPosted: Thu Jun 24, 2010 10:33 am
Milatsmadmini
Bought a wiring loom today.... modified to suit my application (ie, tacho, thermo fan, dual parkers, fog lights and a real fuse box :) ) for just a touch over $500... 3-4weeks
slowly coming along... paint waiting in garage for weather to clear up... gonna be taking it slow, dont want to get him back on the road till at least november...
PostPosted: Thu Jun 24, 2010 10:47 am
filled it up with fuel
PostPosted: Thu Jun 24, 2010 2:15 pm
pushed it up the driveway because my keys were inside and i parked my brother in.
You're so square
Baby I don't care
PostPosted: Thu Jun 24, 2010 3:42 pm
Lifted the head, put in a new exhaust valve, swapped 1.5:1 rockers out for standard S rockers and bought a large cardboard box full of chocolate.
PostPosted: Thu Jun 24, 2010 9:11 pm
Gave the Mini K a nice new battery to replace the old way undersized and always going flat previous one. Also fitted a new indicator stalk switch and returned the wiring for the high beam switching circuit to original. (Previous Owner had wired in a second switch for high beam to get around broken switch in indicator arm). Lights now good and no more jump starts. :P
1971 Mini K
PostPosted: Fri Jun 25, 2010 3:59 pm
Fired up the new 1412 stroker.
Motor runs fine (I think) except the bottom radiator mount bolt is rubbing on the nice new MED competition S balancer. "screeeeeeeeeeetch".. because fitting the new belt drive kit pushed everything out by 3mm.
The lower rad bracket has a date with the reshaping division tomorrow. :P
[edit] typo
Last edited by drmini in aust on Fri Jun 25, 2010 5:42 pm, edited 1 time in total.
PostPosted: Fri Jun 25, 2010 5:33 pm
I'll be around to help you eat them... :P
Might drop off pump on Sunday if OK, in the MINI! 8)
PostPosted: Fri Jun 25, 2010 5:36 pm
Took about three hours, (I'm a 1/4 vent virgin), to put new 1/4 vent rubbers in. What a !@#$%^ of a job :evil:
On the home run to the RWC on Monday morning, can't wait to drive it again. :)
PostPosted: Fri Jun 25, 2010 5:38 pm
Ha ha, I hope your thumbs have healed by then ;)
PostPosted: Fri Jun 25, 2010 5:44 pm
Forgot to ask, why are you swapping out the 1.5's... was this the cause of the burnt valve :?:
PostPosted: Sat Jun 26, 2010 4:39 pm
I took the 1412 for its maiden voyage around the block. I've not revved it hard but the midrange ooph seems nice. :P
PostPosted: Sat Jun 26, 2010 5:30 pm
Whats the plan for a 1360 doc?
You're so square
Baby I don't care
Users browsing this forum: Barkfast and 101 guests
