It is currently Fri Jul 18, 2025 2:28 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Jul 01, 2010 9:01 pm
Mods rock!
From the floor it looks like a pov pak early clubman, but set up for rod shift.....it's had a 'new' front floor section welded in. The Rad shroud could have been changed however the appearance of the firewall (no numbers) also suggests some (bad) funny business.......
PostPosted: Thu Jul 01, 2010 10:01 pm
As you can see from the Photo, we were trying to look for funny business regarding the numbers. There is also no disturbance on the inside of the fire wall of paint, as if there has never been numbers there. The shroud appears to be original. Dose the P4-82 mean anything to anybody.
PostPosted: Thu Jul 01, 2010 10:09 pm
watto wrote:
John Smidt said he often rebirthed Cooper Ss as Mini Ks
Probably not the best choice of words to use on a public forum :?
PostPosted: Fri Jul 02, 2010 7:03 am
Mods rock!
They stamped the firewall numbers before painting.
PostPosted: Fri Jul 02, 2010 1:48 pm
I thought in the early models the rad was stamped before painting and the firewall after. That's why the firewall often looks rusty.
PostPosted: Fri Jul 02, 2010 2:29 pm
Mods rock!
The firewalls are rusty from carelessness when filling the master cylinders.
The firewall is the first section of the car body that is made when assembling the bodies, so it was stamped at this early point to keep track of it.
PostPosted: Fri Jul 02, 2010 7:07 pm
Not really true with the Minis prior to mid 69. On those cars the firewall didn't get the number till after the car was made. On these cars the body number on the radiator shroud is painted and the car number on the firewall is stamped trough the paint.
PostPosted: Fri Jul 02, 2010 8:09 pm
I concur.
The body number was stamped before painting, and on pre-1969 and post-1970 Zetland cars the chassis number, which was stamped after final assembly, is the number on the firewall.
I am not 100% certain of this, but I believe the body number was not stamped on the car until it was a complete body - ie after the body was assembled but before painting. I will check into this a bit more.
Watto.
PostPosted: Fri Jul 02, 2010 8:30 pm
I concur.
Watto.
One thing I also found interesting with the body no. on the rad shroud is that it looks to be stamped by machine, ie the numbers are perfectly even in depth and perfectly spaced. Perhaps they used a machine like a stapler.
The firewall number is the opposite, it is quite obviously stamped by hand. The numbers are unevenly spaced and varied depth.
PostPosted: Fri Jul 02, 2010 9:01 pm
You mean like this? :wink:
Watto. :shock:
PostPosted: Fri Jul 02, 2010 9:16 pm
Or this Mk1...
PostPosted: Fri Jul 02, 2010 9:17 pm
Watto. :shock:
Those numbers on my 79 Moke looked like the guy was leaning drunk when he stamped it- could hardly read the tops of all the letters. :lol:
PostPosted: Fri Jul 02, 2010 9:41 pm
No that green one is Mk2 and that would be by hand. Mine is like Morris 1100's post.
Like this....
...although the YG2S on the green one looks to be stamped using the same method as the earlier body no.
Didn't Mk2's have the body No. (500 less approx) in the bonnet gutter? What do these numbers look like?
PostPosted: Fri Jul 02, 2010 9:47 pm
I'm sure I saw a post on here where they had stamped the first no. (on the firewall) upside down, then obviiously thought "stuff-it" and stamped the whole number upside down. :shock: :lol:
PostPosted: Fri Jul 02, 2010 10:21 pm
The number on that green Mk2 (1969) is as all of the period I have seen. The YG2S is clearly one stamp. The 4 is a separate stamp, and would be replaced by a 1 or a 3 depending on the model. The rest of the chassis number is made up of four individual stampings.
The two Mk1 cowls shown look neater, but the gaps are still a little uneven and the horizontal alignment is not perfect, so I would question if they were done in one stamp or by a machine.
Yes, the 1969 cars had the body number in the rain channel. It had the M2/06 stamped one way, and the body number, 619, stamped from the opposite side. Of course 619 would look much the same from above or below, except the 1 is one-directional and is clearly up-side-down compared with the M2/06 (photo taken from the windscreen side).
Watto.
